Question about Toshiba Satellite 2180CDT Notebook
How to boost the Toshiba 2180cdt laptop to the max? I want to know what socket is used, can i replace the instaled 64mb of rsm with 128mb, and what cpu's are compatabile with its motherboard.
  • stojkens Jun 04, 2009
    I know that the ram is weak, but people, where i live, buy old laptops for car diagnostics and stuff, plus i want to practise my skills in electronics.
  • 87 Answers
WOW 64megs of ram.. dont waste your money, its sold old even if you did upgrade it, it will have trouble with any kind of current software.
Posted on Jun 04, 2009
  • letzfly777 Jun 05, 2009
    Go buy something from atleast 2000 then, the technology you will be exposed to will be so old and outdated it really wont help you much with the modern lingo. If you really want to go further with the project hit up www.newegg.com for parts, it may be so old they dont have it, then hit up www.ebay.com or a local computer shop can get used old parts for dirt cheap! good luck!
  • 4 Answers
It's not that bad; I installed another 128 megs of ram which brought it to 192, which is the  most it can have.  I installed Server 2003 on it, and it seems to run along pretty well.  Don't expect it to play movies very well, or suchlike, with only 2 megs of video ram.
Posted on Jun 22, 2009
I HAVE AN OLD TOSHIBA SATELLITE 2180CDT LAPTOP THAT HAS WINDOWS 98 I TRIED TO UPDATE IT TO WINDOWS XP AND IS NOT ALLOWING ME TO DO THAT. I WAS WONDERING IF REPLACING THE HARD DRIVE WITH A NEW HARD DRIVE IF...
Your laptop will not works with Windows XP. It is simply too old and it's motherboard doesn't support many things. Replacing HDD doesn't have anything to do with this and will not help in any way. Max Supported RAM is 192 MB which is simply not enough for windows XP.
Oct 25, 2010 | Toshiba Satellite 2180CDT Notebook
What is meant by a memory failure Replace dimm 0
There is a memory stick in a socket on the formatter board in the right side of the machine. If you pull the right rear cover to the rear it will come off revealing a metal cover you open by the tab. Once open it shows the formatter board. Inside is a laptop sized memory stick,or DIMM. With power off you spread the tabs to release it then pull the memory out, same as in a laptop. You likely have 96mb RAM - most come with a 64mb memory on the formatter (non removable) and a 32mb option. On the P3005N and P3005DN the memory is required to make the embedded (builtin) network card function, otherwise you can run it fine without the bad DIMM if you use USB. If you want to replace you need a 200 pin DDR2 DIMM in either 32mb, 64mb, 128mb or 256mb value. Last I bought was on ebay for $20 for a 128mb brand new. HP wants like $220 for the same.
May 19, 2010 | HP LaserJet P3005n Printer
ASUS P4S533 Motherboard type of ram to add
Your "ASUS P4S533" model motherboard has three DDR SDRAM DIMM sockets.
You can install any DDR DIMMs with 64MB, 128MB, 256MB, 512MB and 1GB into the three DIMM sockets shown in the picture below. Total system memory can be max. 3GB.
You can see the listed qualified DDR333 memory modules in the picture below and use any of them with your motherboard. Also you can check the ASUS website for the updates.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 10, 2010 | ASUS P4S533 Motherboard
My nvidia gefoce 128mb is showing 64mb now please
well there is a simple solution but i m not sure if u can handle it,,,,
well if you can then remove ur driver for card and then remove the card,
now boot the system with builtin display and run atleast once,
now after that shut down the PC and again reattach the card and boot the system this time install different driver.
i got the same problem but i fixed it as i suggested here.
Good Luck
Feb 14, 2010 | Nvidia GeForce FX5500 128MB DDR AGP Video...
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
May 21, 2009 | Compaq Evo Notebook N150 Notebook
Bios password forgotten on toshiba 2180cdt please help
Remove the battery, open the chassis and locate the internal backup battery (size of a small coin), disconnect it and let it stay disconnected for 24-48 hours.
Reassemble and you are ready to go!
Apr 19, 2009 | Toshiba Satellite 2180CDT Notebook
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
ASUS P5VD2-MX SE video memory sharing
The message on the user's manual only indicates the possible maximum memory that can be shared with the video while in your bios you can see the actual shared memory. I think this could be case to do with the graphics card you are using i.e. is it onboard or an add on. In some cases too the manufactures of the motherboard are not the same manufactures of bios and therefore the manufacturer of the board has given it allowance to share up to 128mb while the bios manufacturer has given it up to 64mb. Remember many of the components on the board may come from different companies.
Aug 25, 2007 | ASUS P5VD2-MX SE Motherboard
Toshiba Satellite 2180CDT Notebook Logo
248 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
