I have a software which is compatible with xp and works fine in my office however i'm using vista in my home pc and when i run this software after installing the same it gives me error message as ''INS32 stopped working'', i read some where in yahoo answers it requires SP1 of Vista i installed that as well but no luck same error message display again.
  • kunal_abc Jun 04, 2009
    Hi Buddy,
    Thanks for your reply...
    well I'm using Parashar Light 6.1 it is a Astrology Software...
    Regards,
    Kunal
    President:
  • 423 Answers
Your software dont support vista
give the name of your software i will check is there any version compatible with vista or i ll bring you a direct link to a software wich has the seame fonctions and support vista
ok
Posted on Jun 04, 2009
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
Sep 30, 2010 | Microsoft Windows Vista Home Premium with...
I have a cosmi office suite flashed 'XP Compatible. Can I assume it will work well on a Vista Home Premium laptop? Thank you for your help.
If its the 2008 version then it should be, there documentation says this.
System Requirements: Microsoft® Windows™ 98 SE, 2000(SP4), XP, Vista; 128 MB RAM, 870MB of Hard Disk space, mouse, DVD-ROM drive required. Microsoft® Windows™ and Office™ are registered trademarks of Microsoft Corporation.
So it says vista is ok
Jul 12, 2010 | Computers & Internet
Cannot install CARD GAMES for Windows
It's probably an issue with Vista, right click on the icon, go to properties, run as administrator, and run in compatability mode for XP. If this doesn't fix the problem, try contacting the software manufacturer.
Apr 29, 2009 | Computers & Internet
Palm TX won't synch with Vista
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Apr 16, 2009 | Intel Palm Tx Handheld
Microsoft office
Vista is the latest, so it can handle the newest things, to the things that were compatible with Windows XP. So, it can run almost anything.
It is natural that Microsoft is going to make Vista fully compatible with its old software. You can even install the crappy old OfficeXP or Office '98
Jan 05, 2009 | Microsoft Office Professional 2007 Full...
Is software Compatible w MS Vista Windows?
You will
have to install and run it using Windows XP Compatability Mode
Jan 02, 2009 | Microsoft Office XP Professional OEM w/...
3dhome arch designe delujx 8 i have this software and when i use it and from the menue i s\choose appearance it is getting stopped and appears window saying software p\not working ok this happen only on...
Because it is an old version--> therefore it is not reasy for W Vista--> Try to use this sw in Compatibility mode--> Desktop--> right click on the program icon--> Properties--> compatibility--> select Windows XP
Patricia
Sep 20, 2008 | Broderbund 3D Home Architect Deluxe 6...
Microsoft Office 2003 Professional - Picture manager
Fixed the problem - Even though the pc checks for updates automatically I should have checked to see if there were any available updates at the microsoft website. There were 3 available and once downloaded and installed the picture manager part of office suite professional 2003 is now working just fine!
Sep 19, 2008 | Microsoft Office 2003 Basic Edition...
Computers & Internet Logo
319 people viewed this question
David Payne
David Payne
