Question about Logitech Alto Cordless Laptop Stand(939000223 Keyboard
My Keyboard's key jammed a bit, so I want to open it for cleaning.
    Scholar:
  • 71 Answers
It might be a loose ribbon cable. If you pull the keyboard up, you can reseat that cable and see if that helps
Please clean the Keyboard once in a month.
If the Laptop is under warranty, please contact the vendor either through Mobile or throgh Printer Hardware Engineer to setllt the issue at the earliest.
Posted on Jul 21, 2009
While my laptop was closed, I accidently spilled coffee on my laptop. I didn't see any liquid on the outside on the laptop and I'm wondering how the liquid could have damaged the keys on the keyboard which are now jammed. I let the laptop to dry by fan and sunlight, but they don't wand to work. Is there any other solotion to fix the keys on my notebook toshiba?
Posted on Aug 31, 2009
I spilled soda on my Macbook Air yesterday. Today, two of the buttons are jammed together. What do to? Help!
You have to be gentle but you can use a tech sized screwdriver and pull the key off. From there you can clean if up a bit more thoroughly.
Feb 28, 2015 | Apple MacBook Air
Some of the keys dont work and CRTL is always press on.
Your Keyboard pad is full of dust or there is someliquid that spilled down the keyboard and the keys are now sticky. This is normally solved by opening up your laptop and have the keyboard pad cleaned entirely. Probably you need to get a computer techincian who is going to help you to strip up the computer and be able to clean the keybord. Make sure you remove the power adpter from the socket and that the laptop battery is removed. Use a smooth cotton cloth with a bit of benzene or methrated spirit when cleaning. Let the keyboard pad dry up for about 20minutes, ten re-connect everything as it was and you should be good.
Aug 11, 2011 | Computers & Internet
The i on my keyboard won't work all the time I have to hit it hard. Debbie
hi there...
Looks like your keyboard have some problems with Dust.
Jammed keys are more caused by getting dusts and other small particles into the keys.
1. Best way of get rid of jammed keys is clean the surface. you can use a small vacuum cleaner for this.
2. Another way is not permanent solution, yet it will give quick results. turn the keyboard back side up. give one or two light slaps on the back of Keyboard. shocks caused by the slaps will move jammed keys. but this is a temporary solution.
Mar 13, 2011 | Computers & Internet
My keys are either not ttttttttttttttyping at aall or do like the t above. More pressure on keys helps.
I assume you have windows.
open start menu
all programs
accessories
ease of access (also called accessibility on xp)
select on-screen keyboard
its a bit slow but it will get you by until you can fix the problem or get a new keyboard. below are three possible alternative solutions:
1. If it is a wireless keyboard then try to change the channel its a little button on the bottom of the keyboard.
2. If its a wireless keyboard change the batteries.
3. If the above two solutions do not help then either carefully take apart the keyboard and clean everything (if you suspect something was spilled on the keyboard) or if its just an old keyboard then the contacts need cleaning they look like little round rubber dots on the bottom of the keys mashing little grid like symbols on the clear plastic sheets. I usually clean the clear plastic symbol parts with a rubber pencil eraser very gently and the black dots below the keys i clean with just a paper towel. I don't use cleaning solutions and try and keep it all dry. remember less scrubbing is more. Look at the unused keys like z to see how they are supposed to look. and good luck. but its easier just to buy a new one.
Aug 24, 2010 | Logitech Computers & Internet
Backspace key does is jammed up
I am providing you a link where in you would find a video as well, which would help you to clean the keyboard of your system,,.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3688868&prodTypeId=321957&prodSeriesId=3688868&objectID=c01631911
Hope this works.
Regards
Ken
May 11, 2010 | HP EliteBook 6930p Notebook PC
Acer Aspire 3000 key jammed on keyboard
Hello !
Remove the key carefully.
With compressed air, clean in and around the area of the key.
If necessary, use Blu-Tack or other adhesive. Put a very small dab and press the key.
Hope this helps.
Sep 19, 2009 | Acer Aspire 3000 Notebook
Laptop number keys acting like F keys
this times your laptop keyboard is grounded or short, please try to disconnect the keyboard and use another or USB Keyboard... and contact your technician for assistance to clean your laptop keyboard.
Jun 22, 2009 | Gateway 7001433 Keyboard
Enter key jammed
carefully take key out,check if broken,clean with solvent alcohol.
Apr 11, 2009 | Computers & Internet
Keyboard removal
Removing the keyboard is not nessesarly your best option, the keys have a rubber boot under them, and are held in place/returned into their postion by a plastic spring/hinge. It is possible to carefully prise the "sticky" key from the keyboard and then clean the relevant bits under it with a cotton bud soaked in a suitable cleaning fluid. It is important to take note of the position of the plastic hinge in the event that you need to put it back together. To refit the "key", position it in it's place on the keyboard and press down firmly, it should click into place
Jun 24, 2008 | Dell Inspiron 6400 Notebook
Toshiba a60 laptop keyboard problem
it's possible that the keyboard is broken somehow, and a key is jammed: from what you're saying, probably the E key.
try checking the keyboard to see if anything is jammed.  if that doesn't work, try plugging in an external keyboard, if possible.
Mar 29, 2008 | Computers & Internet
Logitech Alto Cordless Laptop Stand(939000223 Keyboard Logo
461 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
