Question about Dell 1710n Laser Printer
Dell 1720dn, Tray 1 is making a funny noise when tray gets to half full. Looks to be originating from Rubber wheels. Also is there a way within the web console config to set it to youy both trays rather than tray 1 or tray 2. Many Thanks
As for the noise, take the wheels and flip them inside out. see if that helps. after excessive use the printer tends to wear down a bit. Highly recommend Dell warranty.
Posted on Aug 05, 2009
How do i clean the rollers on my printer?
Paper Tray Rollers Step 1 Turn off and unplug your HP printer. Pull out your printer's paper tray and locate the printer rollers on the paper tray. Each roller is gray or black, and they are made of rubber. Remove the rollers from the tray.
On HP inkjet printers, the printer roller is not on the paper tray; it is on the area inside of the printer where the paper tray slides into the unit. Remove the paper tray and sit your HP inkjet printer upright, so the paper tray area is facing upward, and then look for the printer roller.
Step 2
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the paper or internal tray rollers with the cloth. Fold the cloth in half and repeat the cleaning process until the rollers are free of dust and debris.
Step 3
Wipe the rollers with a dry, lint-free cloth to remove any remaining dust or debris. Let the rollers dry completely before sliding the paper tray back into your printer.
Internal Pickup Roller - Laser Printers Only Step 1 Turn off and unplug your HP printer. Open your printer's front door and pull the printer's toner cartridge toward you to remove it from the printer.
Step 2
Locate your printer's internal pickup roller. The roller is gray or black, and it is made of rubber. Lift the roller upward, towards the front of your printer. Pull the roller gently out of the printer and lay it on a clean surface, such as a desk or workbench.
Step 3
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the pickup roller with the cloth. Fold the cloth in half and repeat the cleaning process until the roller is free of dust and debris.
Step 4
Wipe the roller with a dry, lint-free cloth to remove any remaining dust or debris. Let the roller dry completely before snapping the pickup roller back into place inside of your HP printer. Reinstall the toner cartridge and close your printer's door.
Aug 10, 2014 | Dell 1720dn Laser Printer
It won't "catch" the paper to print. It goes through all of the normal sounds, but won't print.
Check that there are still two rubber bands around the two little rollers. One of mine fell off and got stuck inside.
May 28, 2014 | Dell 1720dn Laser Printer
Printer i making a weird clicking sound. It won't print. It has error light On. Status: load tray 1 / Plain letter Toner level is 80%
check if there is a paper at tray 1. if so, may be the printer is unable to pick up paper due pick-up roller problem. try to remove the tray and look in the middle, there should be a rubber like roller. if its too glossy it cant pick the paper.
Sep 18, 2011 | Dell 1720dn Laser Printer
Rollers make a loud noise when printing...do we need new rollers
Does it make a groaning sound, when picking up the paper from the cassette tray? If it does, sounds like you need to order a set of feed rollers. You can tell if there worn down, just by feeling if there's still some treading, just like a bald tire. Good Luck!
Jul 04, 2010 | Dell 1720dn Laser Printer
My printer, HP injet 1410, could not pick up the paper. Can you tell me what the problem is.
I assume the printer is making noises and moving, TRYING to pick up the paper...
If so, there are 3 possible issues:
1) you have too liittle paper in the paper tray. Add more paper so that the tray is full to around 3/4, not less.
2) You may have too much paper on the tray. Remove some paper from the tray untill the tray is around 3/4 full, not more
3) The rubber rolls that pick up the paper may be dirty with paper dust or dirt. Put 2 drops of alcohol on q-tip and carefully clean them. Let dry 30 mins. before trying to use the printer.
Mar 26, 2010 | HP PSC 1410 All-In-One InkJet Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Clicking noise from Printer tray left side
Usually most of the noises are within the toner/drum unit. HAve you tried another drum/toner. Noises are funny because it's hard to pinpoint exactly where they are coming from!
Sep 22, 2009 | Brother DCP-8065DN Black and White Copier
Dell laserjet 1720dn
Reseat the paper in the paper tray, and replace the pickup rollers for both trays, note the pickup rollers are in the trays and under each tray.
Feb 12, 2009 | HP LaserJet 4250n Printer
Popping noise when i print
if there is a clicking noise, check the paper tray. either the tray is overloaded or the paper guide is not set properly.
it's common for the blue paper tab in the paper tray to slide back. the tab has a little square cut out. make sure that it says "LTR" if you use regular letter size paper (8 & 1/2 x 11 inch).
Dec 12, 2008 | Dell 1720dn Laser Printer
New secondary tray not recognized on vista.
Dell Laser Print 1720 dn Properties window. Click on the last tab called install options. Click the ask printer button. This should update the print driver with the add on drawer.
Oct 30, 2008 | Dell 1720dn Laser Printer
Dell 1710n Laser Printer Logo
350 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
