Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Check Water Tap??
I would say on every 2 loads, we get a flashing CHECK WATER TAP on our readout. What is it and what can I check? We have had the Nexxt Premium set for about 4 or 5 years and never had a problem with it yet.  This is new.
Also having problems when the liquid softener dispenser will mix softener with water, but not drain. Any advice?
  • Anonymous Nov 19, 2007
    every time my washer gets to the spin cycle it say check water tap I have had 3 people check it and nothing is wrong with is- Someone please help!
  • Anonymous Jan 26, 2008
    Im having the same problem - softener doesnt dispense but gets diluted with water on occasion
  • 213 Answers
Remove the cold water hose from the washer look inside the parts of the washer you unscrewed it from, there is a plastic screen in there that needs to be clean out. you can pop it out with a small flat head screwdriver, clean it then pop it back in. also remove cold hose from valve on wall. there is another screen in there that needs to be cleaned. this will fix the problem
Posted on Nov 20, 2007
It is a software bug and happens when there are heavy cloths inside that suck up too much water. Then the water level does not rise fast enough, and the washer thinks that the water tap is closed. I am not aware of a firmware fix. We simply switch the washer on an off, and restart the cycle. Very annoying.
Posted on May 27, 2015
We have a Siemens dishwasherSN66T091GB. The unit is not showing a fault code but the 'tap' light and 'rinse aid' lights are flashing continuously.
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
Rinse Aid symbol light indicates low on rinse additive.
Hope this helps?
Oct 16, 2016 | Siemens Dishwashers
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
a. Check for Kinks.
b. Check for Clogs.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
We can hear water running but it's not filling the wash tub. There is no water leaking anywhere.
check that the tap is fully opened , the filter in the end of the hose is not blocked
check that the tap washer is not jammed off in the tap as they can expand and not move up to let water in
check water inlet solenoid is functional
Aug 23, 2015 | Amana DLW330RA Top Load Washer
Miele w310..drum fills with water slowly after a wash.put my head in...cant hear water leaking into it..
Did you open the water tap complete? When it is open all the way already, please close the tap complete and remove the hose and check the filter closest to the tap. Eventually clean it and put the hose back. Don't forget to open the tap again and check you did tighten the hose. (No leakage)
Feb 04, 2015 | Miele W310 Front Load Washer
Fills with water and then stops and beeps and won;t continue. The hot and cold water buttons are flashing. Waterr starts trickling in and it is slowly spinning but doesn't seem to agitate
Hi just read your posting.The 2 lights that are flashing means your machine has not detected any water level difference.1st turn off both hot and cold taps and 1st remove the cold inlet hose from the machine end,Put the end of the hose into a bucket and turn the tap on.You should get a good flow of water.If you do not get a good flow of water then remove the tap end of the hose and see if you are getting water out of the tap.Check the inlet filters on both ends of the hose to see if they are blocked.If they are blocked clean them with a brush.Check also the water valve end where the hose connected to the machine to see if this filter is blocked. Once you have water coming out of the hose and all the filters are clean refit the hose and repeat to the hot hose.Now select a cycle and push start.If the water flow is good then the machine will work properly.If you still get slow water even when you have good pressure coming out of the hoses then your water valves are faulty.Please reply on how you got on and for further advice.looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Light of a red tap
This is indicating a problem with the water supply, check the inlet hose/s for a restriction or kink in the hose/s.
Make sure the tap/s are fully turned on, and that there is a good water prerssure.
May 27, 2010 | Hotpoint WMA76 Front Load Washer
''Check water tap'' readout
Check you running water to the inlet.
Apr 02, 2010 | Siemens UltraSense 3.7
I get a check water tap error 2 to 4 times a load
I have this problem. This code is due to restriction of water flow. In my case, we have sand in our water, and I have installed a filter between the water line and the washer. When it gets clogged, the flow is restricted and the Check Water Tap message appears. Your washer has filters on the back of the washer itself that may be clogged and need cleaning (which is why I installed the water filter between the washer & water line to prevent it from getting into the washer filter). Your washer manual shows you how to check/clean them. Also, you may have low water pressure during summer months due to lawn watering in your area that could cause this lower water pressure.
Jun 23, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
2,271 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
