Question about Panasonic KX-TA308 Phone
Panasonic KX-T7431, problem:"CO not assigned"
I have Panasonic phone KX-T7431. I tried to setup 1 key dial, but i faced "CO not assigned" problem. Please Help Me.
  • Carl Navarro
    Carl Navarro May 11, 2010
    What happens when you dial "9" from the intercom?
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
SOURCE: phone got dial lock
Can anyone tell me how to open the dialing lock of panasonic integrated telephone system , for which the password is lost.
please waiting reply
Posted on Apr 30, 2008
SOURCE: CO Not Assigned
This to be set via main PABX, Connect a lapop via USB to the main board and using the software of KX-T824S, go to main in COs and define the number of COs connected to this PABX. Apply ad close the program and it will be appearing on your KX-T7730 equipments.
Enjoy....
Posted on Jun 15, 2008
SOURCE: How do ichange the time on Panasonic KX-T7431??
How do I change the display names for each extention name on my KX-T7431 panasonic corded phone?
Posted on Jul 24, 2008
SOURCE: panasonic KX-TGA236JXS gigarange phone is dial lock
panasonic KX-TGA236JXS give error dial lock
Posted on Jan 17, 2009
CO Not Assigned - unable to select and outside line
Did you not assign a speed dial CO buttton to an extension
Mar 11, 2014 | Panasonic KX-T7431 Corded Phone
KX-T7431 try to dial out and dispaly says CO Not assigned, I cannot answer calls either!!!! Hellllppppp
What has happened is that the CO1 CO2 etc buttons have not been programmed to dial the access code for an outside line. You can do this manually by dialling 9 then the number you wish to call. You need to enter the programing mode from the default extension usually EXTN 20 or 21. You need to go into the options and assign the digit 9 and a pause (P). The system will allow you to set different options such as if someone is on CO1 and another user dials 9 from another extension, the system will then assign the next free exchange line, again this must be programmed via the default extension. Let me know if you need further help.
Sep 04, 2013 | Panasonic KX-T7730 Corded Phone
KX-T7431 Ring Off How do I get it on
Please try this, While idle and on the hook, press the mode button 5 times, rotate the Jog Dial (the round circle button/pad) in the desired direction.
Feb 09, 2012 | Panasonic KX-T7431 Corded Phone
We have a KX-TD816 system and I have a KX-T7431 phone. We have no operator so whoever picks up transfers. No one can transfer to me anymore. One other thing all the phones the FWD/DND button blink slowly....
So what happens when they press TRANSFER and dial your extension? What happens when you call someone with a display phone and your extension comes up on the display?
The FWD/DND button shows that you have a FWD or DND condition set on your phone. Try pressing it one or 2 times and see if the display says FWD to xxxx. Now, if it is cleared, from the intercom dial 7104 (busy) or 7105 (no answer) 165 # That sets the CF on your phone.
If the others have lost your DSS button on their busy lamp fields, and truly nobody can "transfer" calls to you, you can reprogram those with PROGRAM 99 (don't pick up the handset) press the button assigned to your extension and dialing 1 + your extension and STORE.
Carl
Mar 23, 2011 | Panasonic KX-T7431 Corded Phone
HAVE LOST LINE 1 AND LINE 2 ON THE PHONE LINE 3&4 OK LINE 1 & 2 COMES UP NOT VALID
When you press PROGRAM 99 and the buttons where line 1 & 2 appear, it should say CO-01 and CO 02. If it doesn't dial 0 01 STORE and 0 02 STORE in those buttons. In a TD system, the lines have to appear in order for you to use them. They don't have to be 1:1, but it's the easiest.
(there's a Group CO button command to save buttons)
Carl
Mar 02, 2011 | Panasonic KX-T7431 Corded Phone
We have the Panasonic telephone system KX-T7431. Some of our phones say "ring off." And, I can't figure out how to get the ringer back on. Thank you in advance for your help.
With the phone idle, press the MODE button 5 times. The display will show: Ringer:OFF, use the jog dial to change the volume level.
Feb 06, 2011 | Panasonic KX-T7431 Corded Phone
How do I change the Name of the person at an extension on the Panasonic KX T7431
press the Program Button, then (**1234), and scroll counter-clockwise through the options with the volume circle. the option should say, "004 ext name set." to enter into that option to change, press the sp-phone button. continue pressing the sp-phone button until you find the extension number you would like to change. once you find it, press the transfer button and spell the designated name using the dial pad. For example, Mike (press 6 and use the volume circle to browse the letter you need from that assigned key- to get M) to continue spelling the name, continue using the dial pad and repeat to assign the designated letter. to store the name, press the "Auto Dial/Store" button and it will beep to confirm.
hope this helps, deanna
Jun 28, 2010 | Panasonic KX-T7431 Corded Phone
Call Screening
If you have a Panasonic Voice Mail system, you can set it up in your mailbox options. Since Panasonic made/makes several voice mail systems, it's better if you know which one, but try option 4 then 1 then 2 to turn on call screening. When a user calls in and keys that mailbox, you get the lovely "record your name at the tone" prompt. Pretty friendly, huh?
Carl
Nov 05, 2008 | Panasonic KX-T7431 Corded Phone
KX-T7731 messed up the co button
Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
Easy when you have the manual :-)
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
Panasonic KX-TA308 Phone Logo
522 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
