After a storm, when i plug in display BOOT, when i turn on Display Please wait
SOURCE: lg kp500 will not boot
Hmm. May you could take out the charger if there is one in it. And take out the battery.
Then put the battery back in and turn it on?
SOURCE: Problems starting up my LG RH188H
I had the same problem. After googling I found that the HDD might be faulty so I unplugged the device, brought it upstairs to unscrew it (to change the HDD for an empty new one). One last check before I really unscrewed the cover - and the recorder started again! After 5 minutes the 'please wait' returned. So, did the same thing again, tried a few times, and the recorder started. Then, I imediately reformatted the HDD, and the problem is now gone.
SOURCE: when I boot my computer I cannot see the display
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: I Have A LG LCD
Look for bad caps, you should replace them in a set, see examples: Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague
http://s807.photobucket.com/albums/yy352/budm/LG%20W1934S/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
