Question about Nikon D50 Digital Camera
Camera won't autofocus
All of a sudden my D50 won't autofocus with AF lenses.For example I have nikkor 50mm 1.8, it would not focus. I can hear a motor trying to focus, but nothing happens. I tried other NON AFS lenses with same result, so i know its not a lens. Possibly my Af motor in D50 is broken. How much am i looking at to fix this ?  Works fine if I use AFS lenses.
  • 2 more comments
  • shagbarkfarm Nov 18, 2007
    nikon d80. Autofocus just stopped working (or I don't remember it quitting). I have tried different auto focus lenses and non-work. the motor whirrs but doesn't alter the focus.
  • Anonymous Dec 08, 2007
    Nikon D50 won't autofocus.
  • rrqr80 Jan 04, 2008
    I have a similar problem. Have tried resetting the camere, with no results!
  • Canoeweasel Feb 14, 2008
    Autofocus won't work. Already cleaned the contacts as described in this link: http://photo.net/bboard/q-and-a-fetch-ms...
I too had D50 autofocus problems and ended up buying a new D300. I then learned that my issue was in the focus areas. The D50 has five focus areas. As you look through the lens, you will see one rectangle in the center and four to the top, bottom, left and right. You should make sure that the center rectangle is highlighted. Use the round thumbdial on the back of the camera to move the focus area.
Posted on Oct 31, 2008
    Scholar:
  • 105 Answers
Auto-focus technology on this camera is controlled by several contacts on the mount that physically mate with other contacts on your lens. It sounds like your mount may be malfunctioning due to wear and tear (if cleaning does not work). This is between $100 and $300 fix depending on which part(s) need replacement.
Posted on Mar 28, 2008
SOURCE:
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
Jun 12, 2016 | Nikon D Cameras
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
Apr 14, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
I have a weird problem. When i put the 50mm 1.8 on my D90 it continues to autofocus even when I switch the camera body to M mode instead of AF with the switch. I would like to be able to manually focus...
You probably have a problem with the A/M switch on the body-- flipping that switch should extend or contract the autofocus pin that drives the lens. This particular lens doesn't have its own focus motor, so there's no way that it could be focusing on its own without the pin from the body driving it.
Try taking the lens off of the camera and looking at the autofocus pin as you flip the switch from auto to manual focus.
Mar 10, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
I got this lens (Nikon AF NIKKOR 50mm f/1.4D) for my D3100 and it doesn't autofocus. I don't knowhow to intervene since there's no switch on the lens itself (because I understand it is small and it doesn't...
The D3100 can't autofocus with this lens. The D3100 does not have a focus motor, depending on the lens to have one. The AF-Nikkor 50mm doesn't have a focus motor, depending on the camera to have one.
To autofocus, you need lenses designated AF-S.
Dec 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
Sep 28, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
May 30, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon 50mm 1.4d does not focus. I can hear the motor make a noise and if I Help it, it will turn. Also it seems stiff when off the camera and you rotate the focus ring.
Sorry to hear about your nifty 50 lens problems. The auto focus motor might have given out and needs repair. You should be able to focus manually with the lens.
Apr 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D50 Digital Camera Logo
1,114 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
