SOURCE: Swintec 7040 Typewriter
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
DickyO
SOURCE: Swintec 7040 & Spellcheck
If it has spellcheck hold the code key down while pressing the (spell) button
SOURCE: swintec 7040
If what you are saying is that you get 2 vertical lines instead of a letter start with a new printwheel, what you are seeing is the hammer face when it misses the printwheel.
DicktO
SOURCE: I have a swintec 7040
Check the pitch selector slide switch on the L. side it should be at 10 or 12 not PS.
DickyO
SOURCE: My Swintec 7040 when I type a letter or word only
There are a few possibilities. If only the tops are printing Press down on the platen to be sure it is fully seated in the side frame. The T/W may be in the overstrike ribbon mode Code period, comma or slash will get you out of that mode.
DickyO
