I have a Sato M-8485S printer and changed my print head 2 times making sure i dont scratch it while i put it on and changed de rubber roller. But still it is well dark at the bottom but light dark after middle to up of it. when i apply a small pression to the up of the head while printing it go back dark but the bottom go light....anybody know what would do this ???
Lo mas probable es que requiere que la cabeza sea bien ajustada en su posicion. Lo mejor es que la ajuste un tecnico calificado en impresoras SATO.
The most probable is that it requires that the head is tightened into position. The best thing is that adjust by a qualified technician in SATO printers.
My all 4- in- one lexmark 6170 won.t feed paper through printer. It pull the paper to the right side...
(More)
My all 4- in- one lexmark 6170 won.t feed paper through printer. It pull the paper to the right side and jam. could ther be something wrong with the roller or is it because i am low in ink?
Paper jams when using the ADF. When feeding paper thru the ADF it often jams. Is there an easy fix...
(More)
Paper jams when using the ADF. When feeding paper thru the ADF it often jams. Is there an easy fix to this problem??
