Question about Toshiba Satellite A135-S4527 Notebook
Appcrash probleme in vista still after i installed
Appcrash problem in vista still even after i installed regcure what is the solution no thing work
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
structure.
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
Tip
How to Erase RegCure from your pc system
<span><span> <p>RegCure is a registry repair tool that allows you to solve registry errors, such as missing dll files, damaged registry keys and corrupt settings. If you are no longer interested in this program, or prefer to install and use a different registry repair tool, uninstall RegCure from your<span> </span><a href="http://www.ehow.com/computers/">computer</a>. Uninstalling RegCure is a quick and simple process for Windows 7, Vista and XP users.<span></span><br /><br /><span></span> <span>Instructions</span> <ol> <li> <ul> <li><span>1</span> <p>Click the "Start" menu and then click "Control Panel." Click "Uninstall a Program" if you are using Windows 7 or "Programs and Features" if you are using Vista. Double-click "Add or Remove Programs" if you are using Windows XP. The programs window will launch.<br /></li> <li><span>2</span> <p>Scroll down and click "RegCure." Click the "Remove" or "Uninstall" button. If prompted, enter your administrator password and confirm you want to remove the application. The setup wizard will remove the program.<br /></li> <li><span>3</span> <p>Restart your computer to complete the process<br /></li></ul></li></ol></span></span>
on Dec 27, 2010 | Computers & Internet
APPCRASH error please help
When program files or files within your computer's registry have become corrupted, this can cause the programs to unexpectedly crash. When a program crashes, you will likely get an Appcrash error. The error message will say "Windows Media Player (or whichever program has crashed) has stopped working" and then list rows of technical information regarding the cause of the crash. Unless you are a computer programmer, you may never fully understand what caused your program crash, but that doesn't mean that you can't fix it.
Delete any new programs that you have downloaded. Often, the cause of corruption in a computer system are bad downloads that bring harmful files onto your computer. If you started to get the Appcrash error on your system after downloading a new program or software from the Internet, it's highly likely you have downloaded a bad product. Use the "Add/Remove Programs" feature in your "Control Panel" to get rid of the program immediately.
Uninstall the program that is crashing. It is possible to fix the program's corrupted files while the program is still installed, but to make sure that you clear the program files completely, it is safest to completely uninstall it from the system.
Run a full scan of your computer. Your computer should already have antivirus software installed that can scan for corrupted files and either fix them or delete them from your system. If you do not have antivirus software on your computer, that could be a big part of the problem. Purchase and install antivirus software as soon as possible. These are designed tor from outside threats. Once you have the antivirus program installed, open it and click "Scan Computer." The antivirus scan will isolate bad files and you will be given the option to remove them from your system.
  1. Reinstall the program that was crashing. Now that the corrupted files have all been removed, your program should run smoothly after reinstallation.
  2. Check for program incompatibility. If, after a thorough scan and cleaning of your computer and reinstallation of your program, the Appcrash errors continue, the program you are trying to use may not be compatible with your program. For instance, there are some DVD softwares, such as Media Now, that do not work correctly with Windows Vista. These lists can be easily found online. If this is the case, you will have to purchase a software program that is compatible with your OS
You should download a program such as RegCure and run it from time to time. If you are unable to download a copy let me know and I will give you a link on my web where you can download it.
Jan 16, 2010 | Microsoft Internet Explorer 7
Consent UI for administrative applications has stopped working
Consent.exe is part of Windows Vista UAC (user access control). If you are having problems, try going back to a restore point and see if you can add/remove programs. If you don't have a restore point where you can do that, then you will have to use the recovery CD which will require the admin password. If you didn't set a password, it could be blank, just try pressing Enter.
Aug 31, 2009 | Microsoft Windows Vista Home Basic Edition...
Lenova computer running Vista crashes most applications. Two examples: Family Tree Maker: Problem Event Name: APPCRASH Application Name: FTM.exe Application Version: 18.0.0.86 Application...
Weird category.  Seems OS- or program-specific enough.
The exception codes are supposed to give you insight into what's going on, (Intel exceptions C000 00029 and E043 4F4D in the context of Vista or your CPU in particular, say) but perhaps you should try the Vista equivalent of WinXP's RunAs options, where you can run them as older applications and dodge some incompatibilities.
Similarly, you might want to create a VM (or runtime jail; many, many options to be had there...) and try it in that context, so that if the program's spoiling things at least your system won't need to worry or crash.  The easiest thing of course is to find updates of those programs that promise to play well with Vista.
Aug 22, 2009 | Computers & Internet
Dell 926 will not print black and gives alignment error
Has this printer been sitting for a period of time? Inkjet nozzles will dry up...replace the cartidge, even tho it may be half full, it prolly has dried out
Jul 24, 2009 | Dell 962 Photo All-In-One InkJet Printer
REGCURE - HOW MUCH $
I have something even better and it is free.
It is called "glary utilites" It does the same thing and offers more.
you can download it from glaryutilites.com or any other website and is free.
Regcure is over $120
Jul 09, 2009 | Microsoft Office Professional 2007 Full...
APPCRASH Problem since I have Windows Vista and I could not able to install .exe file
BAD DEAL! IF IT'S COMPATIBLE FOR XP IT WON'T WORK IN VISTA. VISTA IS NOT BACKWARD COMPATIBLE. HECK IT BARELY LIKES ITS OWN PROGRAMS AND I CAN BARELY GET THEM TO RUN. I STILL HAVE NEVER BEEN ABLE TO DOWNLOAD VISTA, SP1 AND I EVEN GOT THE CD! BUT THAT ****** WILL NOT INSTALL NO MATTER WHAT! NO WONDER MS IS BRING OUT WINDOWS7 AND CANNING VISTA! BUT AS TO YOUR PROBLEM, I DON'T KNOW OF ANY WAY TO FOOL VISTA INTO ACCEPTING THAT PROGRAM. IT JUST WON'T DO IT. HECK, I CAN;T EVEN GET PROGRAMS FROM PC WORLD TO DOWNLOAD TO MY VISTA HOME PREM! AIN'T THAT A KICK? WHAT A PAIN. ALMOST NOTHING DOWNLOADS UNDER VISTA. IT'S A NIGHTMARE! THERE MIGHT BE SOMEONE WHO HAS SOME TRICK TO DO IT BUT I HAVEN'T BEEN ABLE TO DO IT.IF YOU HAD TWO DRIVES YOU COULD INSTALL IT ON THE OTHER DRIVE, BUT OTHERWISE IT'S BAD NEWS. SORRY I COULDN'T DO MORE.
ARCLIGHT1217
Nov 05, 2008 | Computers & Internet
Appcrash
Problem signature:
Application Name: godfather.exe
Application Version: 0.0.0.0
Application Timestamp: 43f63da6
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6000.16386
Fault Module Timestamp: 4549bdc9
Exception Code: c0000005
Exception Offset: 0002e48e
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional Information 1: e51a
Additional Information 2: 4c0d4d78887f76d971d5d00f1f20a433
Additional Information 3: e51a
Additional Information 4: 4c0d4d78887f76d971d5d00f1f20a433
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Feb 01, 2008 | Acer Aspire 5610-4648 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
278 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
