Question about Pentair 1hp Whisperflo Pool Pump In - Ground
Pool pump starts & stops on its own outside of programmed run
I have a Pentair Whisperflo 1 1/2 hp pool pump with Jandy Aqua Link Controller. When the program calls for the pump to be off, the pump will sporadically come on for a split second and then shut off. This happens randomly.(The pump may kick on and off 1 time in an hour, or it may do this 3 times in 15 minutes, or not at all for a day.) The relay has been changed, the outside board, as well as the board in the controller inside the house have all been changed out, and still the pump kicks on and off. Could the "new" relay be defective? Will this starting and stopping of the pump harm the pump? Could this be a wiring problem? Please help! Thanks
    Problem Solver:
  • 11 Answers
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Posted on Aug 11, 2009
Testimonial: "The problem has been fixed----it was a bad outside air temperature sensor. Thanks for your help."
Want to replace with either a two speed or variable speed motor, and suggestions?
You will need to install a special controller if you change to a 2 speed. Because there will be an additional wire (4 wires vs. 3) with a 2nd speed to operate.
If you go with a variable speed motor, then again, a special controller will be required to utilize a reo-stat type of switch with will allow a selection of slowly increasing voltage to motor which will in turn allow the motor to spin quicker.
Instead of the hassle above, just go with a "One deal package" all nicely bundled ready for installation. It has it all within it - What...? A variable speed complete pump! That will be the sweetest thing for you if you are looking to go that route!
Check these out...
Aqua Leisure Relax in Comfort Pool Lounges
Good Luck
Apr 04, 2015 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
How to change the start and stop time on a pentair pump
see you tube video on Pentair whisperflo programming it helped me
Jul 09, 2012 | Pentair 1hp Whisperflo Pool Pump In -...
Pentair wf26 pool pump motor noise
try standing it on a piece of inch thick rubber type foam and see what happens
Apr 12, 2012 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
May 25, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
Pentair 2 speed pump will not go on high speed jandy system indicates on high but pump remains on low
check to confirm jandy system is wired for high. if all wiring is correct you could have bad hi speed windings.
david
Apr 24, 2009 | Pentair 2.0 Hp Whisperflo Pump
Pentair 1hp Whisperflo Pool Pump In - Ground Logo
590 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
