Question about Dell Computers & Internet
Inspiron 1525 - Restarts no matter what
After so meny tests, everything seams to be working properly! It is just the problem that it wond stay down. Every time I shutdown in all formes (except Press and Hold the power buton) it restarts within 10-30 seconds. Anyone, had resolved this type of problems please let me know how?
Tks
  • IQUIT May 11, 2010
    Have you reset BIOS defaults and flashed BIOS to most current version?
    Problem Solver:
  • 18 Answers
In Vista go to Start button > control panel > Classic view > power options
select "what the power button does when I shut down"
Next select "shutdown"
Posted on Jun 13, 2009
INSPIRON 1525 NOT STARTING UP
Try taking the battery out then holding the power button down for 30 seconds (this clears the power in the machine), then power back on and hopefully should work.
Apr 15, 2013 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 functions keys are not working
The two most common input devices for the Dell Inspiron 1525 are the keyboard and mouse.
Although the mouse is an almost indispensable tool in navigating through programs and websites with your laptop, the keyboard offers quick shortcuts to open and manipulate files and information.
An unresponsive keyboard can indicate a deeper problem and require troubleshooting to narrow down the cause and find the proper solution.
Laptops are collections of complicated computer components and sometimes a file or two can become damaged and affect the way the machine behaves.
The first action to perform when things aren't working right is to reboot. When your laptop restarts, it essentially resets all the files and programs to the "starting" position and corrects any small errors that may have occurred during the last session.
Eliminate Conflicting Hardware
With an almost unlimited number of accessories, programs and software available for your 1525, it's possible something else installed on or connected to your computer is interfering with its ability to properly communicate with the keyboard.
Shut down the laptop and disconnect everything attached to it.
Power up and test the keyboard.
If it works, start reconnecting each accessory, one by one, until the keyboard stops working. You've found your culprit.
Try External Keyboard
To determine whether the problem exists in the keyboard itself a hardware problem or with the software that controls keyboard function, attach an external keyboard and see if it works.
If it does, the problem with your 1525's keyboard may lie in the keyboard itself, such as a loose cable.
If the external keyboard doesn't work, the problem may lie with the operating system's software that controls keyboard function, such as the drivers.
Update Software
Sometimes a laptop will stop functioning properly due to out-of-date drivers or other software. Always check Microsoft's website for any updates available for your operating system and check Dell's website for updates to the drivers and BIOS installed on your system.
In many cases, installing the latest updates will help correct issues and keep your system working smoothly and efficiently.
Check for Damage
Physical damage, such as a liquid spill and short circuits, can prevent the keyboard from operating properly.
Any amount of liquid spilled on your keyboard can cause a short circuit to the components and a sticky beverage such as juice or soda can cause the keys to stick and become unresponsive.
Clean the spilled liquid from under the keyboard fix sticky keys.
Laptop repair shops can do this for you if the task is out of your comfort zone.
Hope this helps
Oct 23, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
The computer shuts down on its own, stay on for about 5 mins. I made everything is plugged in.
Restart the computer in safe mode (Press F8 key when you restart computer and see the dell log untill you see the Advanced boot options, choose safe mode using your up and down arrow key and hit enter).
you system will load the basic windows drivers and will not connect to internet.
Please keep your system on and work with it for some time and test it. Even in this mode if your computer restarts then its definitely due to heat, else its due to application errors or driver errors
Dec 25, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Laptop keeps turning off laptop only stays on for 5 minutes, max, before powering off. no warning, just turns off. battery and power cable/converter is good. Tested with another 1525 battery and cable....
Two factors usually cause this
Factor 1: Overheating due to Dust and Dirt contamination inside the Notebook.
Open the Notebook and blow it with an Air blower mainly near the processor area.
Check the CPU cooling fan is working properly or not.
if the fan is not working properly even after the cleaning then you need to replace it.
Factor 2 : Virus, Worm or Malware infected system cause the system to repeatedly restart ot shutdown.
get your system clean with a good Antivirus like "Kaspersky Internet security 2010" or A-squared Anti-Malware. Both can detect malware,adware, spyware,trojans etc.
Check out which one work out for you.
Jan 07, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 laptop shutdown problem
The Laptop is not responding to the Software request sent to the BIOS or one is not getting there.
Best Solution is to make sure all of your Microsoft Updates are performed. Not just the Critical ones... but all that apply. You may see several hardware driver updates.
This will help the Software and Hardware to communicate with each other...
Jan 01, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
Dell 1525 installed updates, computer re-booted on 3rd update says installing update but it will not and computer shuts down and restarts and continues doing the same.
1. Turn off the computer.
2. Turn on your computer and start pressing the F8 key on your keyboard.
3. Select last known Good Configuration from boot Menu and press enter
4. This option should work but if it does not work try Safe mode option
Jun 23, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1525 integrated webcam driver
The location you download drivers to does not matter, windows installs them to the proper location. Either the cam or the connecting cable has failed.
May 25, 2009 | Dell Inspiron 1525 Laptop Jet Black
My dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Mar 15, 2009 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
