Question about ASUS P5V800-MX Motherboard
Have no power distribution on harddisk and switches but led indicator has a light
  • 32 Answers
Possible Solution(s):
- You and/or something else may have caused a short circuit to the switches in the main board itself.
- Try checking for any signs of psychical damage, this may have cause a short circuit and/or hard drive failure.
- Your Main board may have completely failed and only the simplistic processes are running; only LED indicators are working.
- Its time get a new Main board; a new one on the market "shines" the most.
Hope I helped
- donman92
Posted on Jun 04, 2009
When I want to print it says error 6C10 switch off switch on. Doesn't work!
that indicates full waste ink pads/absorbers. to reset the counter try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
any way if the absorber/pad is full, it have to be cleaned!
Sep 20, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Will not turn on when power button is Dell Inspiron 518 will not turn on when power button is pressed. Green LED on back of powersupply lights and orange LED on motherboard turns on. No fan operation on...
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 13, 2011 | Dell Inspiron 518 Desktop Computer
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to connect my led lights[that is the red nd green light ] with my 865 chipset''......where r those pins on the motherboard ??
in *********** board where the reset & power botton is connected same place you can find HDD LED for Harddisk and Power LED for power, please be carefull with the sign designation about (+) and (-) it is indicated in the board and pin.
Jun 12, 2009 | EliteGroup ECS 865PE-A7 Intel 865PE...
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Red light on power up. No image on monitor. Pc fans working.
On a computer mainboard there are usually a number of connecting pins right next to one another called RESET, POWER LED, HD LED etc.
The power led often leads to the green LED next your power button to show that the juice is available and on. The cable that leads to the red LED is usually the HD LED which shows that a disk drive is being accessed.
Since the red LED is active, one of your disks is probably being accessed and that's where the problem is. Either the disk is damaged, the cable is still not inserted properly or the bios is having problems identifying one of your disk drives.
1) Power the computer off. Take the power cable out. Make sure that you are grounded (have no static charge on your body). Take all of the cables between your mainboard and your disk drives off.
2) Plug in one of your disk drives, reconnect the power cable, switch the power on and watch the monitor. If all goes well you will see that the bios has recognized the disk drive and will simply display a message that the operating system for example isn't available or no harddisk drive is present (if you connected something other than a harddisk drive).
3) repeat this process with the other drives, powering the pc completely off each time and then adding a new disk drive.
4) once you've reached the point where the red LED drive is displayed but no message is available, you've found the culprit that is keeping your pc from booting properly. Hopefully the cable has just been stuck on improperly or the cable is damaged (Check it), rather than you having disk drive damage.
Mar 27, 2009 | Aspire Red X-Cruiser Mid Tower ATX Case...
Diagnostic Indicator
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Dimension 2400 PC Desktop
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
ASUS P5V800-MX Motherboard Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
