Question about Intel Motherboard
Adding extra ram -Regarding
I have 945gcnl motherboard & 1GB DDR2Ram
I want to increase my ram memory 2GB, there is two pci slots so i was inserted the additional 1 GB ram but my pc working in only 1 GB no improvement and showing only 1 GB ram in system properties what will do for insert an additional ram?
    Problem Solver:
  • 27 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-1
Posted on Aug 29, 2009
    Problem Solver:
  • 9 Answers
IF IT IS RUNNING XP DONT WASTE YOUR MONEY IT WONT DO ANY BETTER, YOU NEED TO DO IS GET 2 MATCHED 512 STICKS SO IT WILL BE DUAL CHANNEL. XP IS SLOWER WITH MORE THAN A GIG OF RAM.
Posted on Jun 04, 2009
    President:
  • 1,901 Answers
Are you absolutely certain that both are DDR2? If so, try each module by itself and see if the computer will boot up. If it does on one and not the other, one is either bad or the wrong type of RAM. I might also suggest that you ensure the modules are installed securely.
Crucial.com also recommends that for maximum performance you should install a matched pair of modules, although it is not necessary.
Use the Comment button to reply.
Where is the memory slots for the Panasonic CF-T8. I know about the one on the back where it the other slot?
According to Panasonic's Toughbook CFT8
owners manual there is only one slot where
you can add extra RAM. The other memory
is "non-removable" and probably soldered
directly to the motherboard.
I double checked on the Kingston RAM Website:
Bank Schema: 1GB Standard:
[1GB] (Non-Removable)
or
3GB Standard:
or
2GB Standard:
[2GB] (Non-Removable)
or
3GB Standard:
Sorry to disappoint you but that is how they
made the CFT8 Toughbook.
If it is any consolation, the CFC1 and CFC2 both have
two (2) slots on the underside of the unit. Not the CFT8.
Good Luck,
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 17, 2014 | Panasonic Toughbook Cf-t8 Win7 Core2 Duo...
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
I have msi motherboard p4nsli with 1 stick 2gb memory but in booting the memory shows only 512 mb instead of 2gb,..what seems to be the problem & a posible solution for this? Thank you.
Your MSI motherboard may use Interleave RAM. This means you need to insert 1Gb RAM modules in each pair of memory slots.
If your motherboard has 4 memory slots and they are color coded in pairs, then this motherboard uses Interleave RAM. Insert 1Gb RAM modules into the menory slots that have the same color.
May 07, 2011 | Computers & Internet
Asus M2V890 motherboard supports max 2GB memory per specs. Is there any way to increase this, or am I stuck with 2GB?
2GB is enough for the MB you are using, if there are no more slots on the MB then you cant increase them.....every slot has a MAX limit of RAM card that can be installed, check the MB specification....i guess 1GB per slot is the MAX...so 2 slots...2GB
Nov 18, 2010 | ASUS V2-M2V890 AMD SktAM2 Barebone System...
Ram
Okay, you don't need two video cards. Your 4 memory slots are grouped in two's. One set is black and blue, and the other set is black and blue also. These are your dual memory channels.
The reason you can't see more than 2 gig ram is because you are probably not running 64 bit Windows with a 64 bit processor.
32 bit windows will only display 2 gigs, but max memory is 4 gigs. It will draw on the extra 2 gigs if ever it is needed, but this does not happen very often, if ever.
Hank
Jul 14, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
PC Motherboard Query
Hi there
This Socket 754 board will accept up to 3GB of DDR 400 memory and an 8x AGP video card
Thanks for Using Fixya
Jan 13, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Aug 23, 2007 | Abit BL7-RAID Motherboard
Intel Motherboard Logo
78 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
