Question about Garden
Briggs 98902 carburettor spring diagram. Need pic showing where springs hook onto throttle linkages, someone has mucked around with them. Unsure how it is meant to work. Moving throttle cable has no effect on butterfly, other than amount the bigger spring is stretched looks to affect its governing properties. There doesnt seem to be any direct control of the butterfly.
  • Anonymous Mar 15, 2014
    Need pics to connect rear controls on 28 horsepower the throttle and governor springs
    New Friend:
  • 93 Answers
Go to Briggs & Stratton on the web and pull up the diagram.
Posted on Sep 15, 2009
  • wishfull2 Sep 04, 2010
    I couldn't find a diagram so here's a digital shot of spring connections I used ..with success
    I bought new springs
    Red colour is Long Spring Yellow is short spring
    Both connect to hoop
    Pic herehttp://img196.imageshack.us/i/victasprin...
    Hope this helps
  • Jamaal Crushaa
    Jamaal Crushaa Apr 21, 2015
    thanks again.. the only pic on the whole f'kng internet.. if i ewanted a diagram i'd ask for one..for the earlier poster.. go jumpo in the river..your "help' was useless
  • 1,169 Answers
The butterfly is indirectly control by throttle cable via spring tension on the governor spring. This is from the service manual.
briggs 98902 carburettor spring diagram - 2320293-ua02xfnihps20wrlhulnoxra-3-0.png
Posted on Apr 21, 2015
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
How do you assemble the two springs on a sprint 375 briggs and stratton ?
The ends of both springs hook at the loop of the metal linkage connecting the governor vane and throttle shaft. The other end of the small spring hooks onto a small upright plate approximately 1 inch towards to the front of hooked end of the spring. The longer spring hooks onto a large hole in the throttle plate.
A problem that does occur is the plate becomes bent when the mower us pushed under shrubs. This drops the speed of the mower to a low idle. If this is the case then with a pair of pliers, gently twist that metal plate to obtain a RPM setting of 3,100. Don't be tempted to increase the revs to much or the conrod will break and punch a hole through the engine block.
May 07, 2014 | Craftsman Garden
How to hook up governor spring and throttle linkage on a briggs and stratton 8hp
From the governor 'vane', on end with a small hole in it is for one end of the spring........the other end of the spring goes to the throttle arm on the carb. YOU MUST HAVE THE CORRECT SPRING WITH THE PROPER LENGTH AND TENSION!!!
Sep 21, 2013 | Garden
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Large spring has come off near carb also a small leaver tpye,cannot control spedd and it uses a lot of petrol
By large spring do you mean long? it can be one of two things throttle return spring or the govener control spring both connect to the carburator and thelong one connetes to the timing device on the side of the block.
Aug 21, 2009 | Garden
Garden Logo
5,635 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
