Question about Amana ABB1927DE Bottom Freezer Refrigerator
Evaporator coils icing up
The refrigerator and freezer work fine for a week or so as the evaporator coils gradually ice up until the are completely iced and I need to turn it off and defrost.
     This has be going on for the past 6 weeks.  The time for the coils to freeze up is getting shorter each time.
     I replaced the defrost control circuit board when the problem first occurred but there was no change.
   The most recent time I used my air compressor to blow out the drain after it was defrosted.  The result was a faster freeze up.  It has been just 4 days and the coil is almost completely iced.
  • 3 more comments
  • Jijm Nov 09, 2007
    First, my unit is a Sears 22' Bottom Freezer Refrig, model # 596.77259200, 2002, made by Amana.
    Here is where I am at today. About 2 weeks ago I emptied the bottom freezer for the 4th time, defroated, checked all door seals and put it back in service, and set the STAT to "colder". I have opened the door for less than 30 seconds per day to check the coils and the temperature. The coils are 100% free of ice and the temperature has been zero to minus 5 degrees F. The refrigerator STAT is set on 5 (7 is the highest) and the temperature is 30 degrees F. We have been using the refrigerator as normal. Cerfer 39 thinks it could be the defrost heater which sounds reasonable but he is not familier with the Amana bottom. According to the sketch and part description in my repair parts list book, the evaporator section shows a part # 67001085 as a Heater, evaporator. It appears that there may be 2 of these, one on each side of the evaporator coil.
    My question now is how do I get to these heaters? Is this a 4 hour job for an experienced tech that would take be 2 days to do myself. If there are 2 heaters, are they in series? I am getting uniform ice buildup across the coil. I would not expect that if only one heater were burnedout. Is there a relay that controls power to these heaters that could be burned out? Can I get to it?
  • Jijm Nov 13, 2007
    I sure hope it is easy as you say. It appears that I need to remove the icemaker before I can remove the back panel. When I remove the back panel of the freezer section, is there any reason I can't turn the unit back on while I am waiting for a replacement defrost heater, provided it is found to be burned out?
  • Jijm Nov 14, 2007
    Thank you Cerfer 39,
    I have more than enough tools but not much experience working on refrigerators and freezers. Thanks for the encouragement. It is sure good to have an expert to answer my questions, to build my confidence, and shorten my learning cure. I hope to tackle the job on Saturday, 17 Nov.
    Jim
  • Jijm Nov 17, 2007
    Cerfer39,
    I removed the icemaker and back panel to expose the coils etc.
    It has been 16 days since last defrost and everything was frosted over.
    The first 5 days we kept the freezer closed and the coils seemed ok.
    For the last 11 days we have been opening the freezer twice a day to get ice.
    I defroasted the coils with a hair dryer to find the defrost heater.
    I popped the connectors to the defrost heater and it checked to be 28 ohms with my Simpson meter and a little higher with my pocket digital meter.
    That computes to 500 watts at 120 volts which sounds reasonable to me which would mean the problem is not a defective heater.
    I would expect there is a relay somewhere that is not closing or the control circuit I replaced is still defective.
    Where do I go next?
    Jim
  • Jijm Nov 27, 2007
    OK Cerfer39,
    Here's what I did over the weekend. I checked the parts list and found only one (1) additional item called thermostat kit. I had no schematic and there was none on the back of the new refrig/freezer. I checked the diagram on the back of our older Amana w/ bottom freezer but it had a defrost timer and the new unit has the "Adaptive Defrost Module". So, I traced the wires and sketched out the circuit with the help of defrost cycle info from Appliance411.
    I determined that the evaporator fan was working just fine and the next thing I might be able to check was the Defrost Termination Thermostat. Of course it is hard wired, so I skinned the insulation off and installed a jumper.
    The freezer has been working with normal frosting for 4 days and actually went into a defrost cycle that removed all frost from the coils. Looks like the defrost termination thermostat is the problem. Do you agree? Who do you recommend to get the best quality part at a resonable price? This is not an expensive part.
  • 213 Answers
The defrost heater on this model is black. same material the element in your oven is made of. it runs across the bottomof the evap. slightly going up thr right and left sides of the evap. if you trace the wires back youll find that one side will hook into a defrost thermostat. this part is clipped up at the top of the evap. its about the size of a nickel. look at it to see if its swollen. the plastic top of it will look like its popped off alittle if its bad, inmost cases. either one of these two parts, defrost thermostat or the defrost heater can cause your problem
Posted on Nov 27, 2007
  • 709 Answers
Hi Jijm,
The time is really fast for the Evaporator to be freezing up like Sparkgap said. A possible solution is that you Defrost heater is burned out. It is usually located at the bottom of the evaporator encased inside a Glass Tube with a wire connected to both ends. If you have already accessed the Evaporator coils look for this heatrer and remove it for examination. What I find is the heater is usually burned in two. You can use a Volt ohm meter to check the resistance across the two connections, It should read less than 20 ohms. You can get another heater at www.repairclinic.com. Since you are icing up so fast, you might have your thermostat for the freezer set to wide open making it run all the time to gain the coldest temp possible. Please do not knock what Sparkgap said as you could have some moist air getting into your freezer through the door seals. If your heater is ok, then it may be the Defrost temperature sensor. This is unlikely, but still possible. I am not familiar with the Amana fridge so I am not sure where this sensor is located. It does have to be somewhere around the evap coils.
Posted on Nov 08, 2007
  • 3 more comments
  • Greg Stokes
    Greg Stokes Nov 08, 2007
    Normally when you have a problem with icing it is related to the auto Deforsting system. normally if you have manually defrosted your Freezer, it should be good for 15 to 30 days. Granted Icing will build up with time. Completed Icing where you cannot see the coils due to having solid ice all around occurs over 30 days.. you did the right thing clenaing out your drain. That will get moisture out of your freezer better. Icing also moves faster when you have high humidity in your freezer.
  • Greg Stokes
    Greg Stokes Nov 09, 2007
    It is a simple job and should take a technician about 20 minutes to change and I believe there is only one heater. It might take you about 30 minutes. First of all you need to find the heater at the bottom of the coils insode the freezer. Find outif it is bad or not. If it is bad youneed to go to www.repairclinic.com where you can look up your Fridge and thet parts will display so that you can pick it out and purchase it. Have you removed the back panel inside the freezer yet? It will either have phillips head screws or 1/4 inch hex head screws. If you have a 1/4 inch nut driver it makes the job easier if you have the 1/4 inch hex head screws. Remove the back panel and look at the bottom of the coils for this heater.
  • Greg Stokes
    Greg Stokes Nov 13, 2007
    Hi Jijm,
    There is no problem with allowing the Freezer to run while you wait on parts. You can even run your Ice maker. I do suggest that when you get in there and it is defrosted to get as much moisture out as possible. If you leave moisture in the freezer is will get into everything and freeze up. I have seen the Icemakers motor frezze up when water stood in a freezer. Weird stuff. Do not get worried, just do this job one step one screw at a time. Remove the icemaker. Remove the shelves. Find one of them cheap multi bit Screwdrivers. Those Screwdriver have a 1/4" allen hole to put the bits in and they work great at removing those Hex head sheet metal screws in the back of Freezers. Keep me filled in how things are going. I get alerts every time you post a comment.
  • Greg Stokes
    Greg Stokes Nov 17, 2007
    Hi Jijm,
    Team work here man. Good job, I told you it was not that bad. If you can get back to the diagram that points out parts, you need to look for the temperature sensor or switch. Some Freezers have a Defrost switch, some have sensors. Another thing could be the FAN. If it is not circulating the air well, then Defrost could be comprimized
  • Greg Stokes
    Greg Stokes Nov 28, 2007
    Hi Jijim,
    Go to www.repairclinic.com first and identify the part number. The go to ebay and get it for less.
  • 363 Answers
The only possible source of water to freeze on the coils in such a short time is from the outside atmosphere. Check the door seals.
Posted on Oct 25, 2007
  • Martin B
    Martin B Nov 08, 2007
    Welcome back!
    Sorry to see you didn't like my proposed solution. I probably wasted your time by suggesting checking the seals.
    Is there anything else you wish to add to help us diagnose this mysterious problem?
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Freezer goes -9 and fridge goes to 40 I have set it to 0 for freezer and 34 for fridge it changes on its own
Depends on type of refrigerator freezer you have, but you need to realize that the evaporator (cooling coils) are in the freezer, and the cold air produced in the freezer is then circulated via an evaporator fan into the refrigerator section. The thermostat the cycles the compressor motor is located in the refrigerator, and the compressor will run until the temperature reaches the desired level in the refrigerator. On most units, the freezer temperature setting simply regulates how much cold air is circulated into the refrigerator.
What you are describing is that the freezer is working fine (almost too good), but the air is not properly getting to the refrigerator area. Several things can be causing restricted airflow, including a faulty evaporator fan, icing of the evaporator coils because of a malfunction in the automatic defrost system. Check to see if there is frost or ice build up in the back or bottom of the freezer. The proper temperatures should be around 0 F for the freezer and 38-40 degrees F for the refrigerator.
Feb 25, 2015 | Refrigerators
What is causing my sub zero moled 590 , made in feb 93 to gradually warm up?
yeah vacuuming behind the fridge is a good start this will help the fridge preform better as when dust builds up on the condenser it will cause the discharge to be hotter than it should be making the cooling in the case not as efficient. i would start by removing the pannel in the fridge and seeing if any ice is on the evaporator
May 22, 2014 | Sub-Zero Bottom Freezer Refrigerator
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Refrigerator not cooling
If you had ice on the coils you will need to replace the defrost thermostat. Here is the part to order.
Nov 17, 2012 | Samsung RS265TDRS Side by Side...
Freezer defrosts, things melt then frost up
You have a defrost system failure. You can verify this by take off the rear shield of the freezer and looking at your evaporator coil. If it has a large amount of ice built up on it, then your defrost circuit is not functioning. The defrost circuit is made up of the heater (WR51X10055), the defrost thermostat (WR50X10068) that are located in the freezer section close to the evaporator coils and a timing circuit that is part of the main control board (WR55X10942) which is located in your component compartment at the lower rear.
NOTE: If you defrost the evaporator coils the refrigerator should operator normally for about two weeks (until the ice builds back up).
Hope this helps! Hal aka ImJustAvg
Jan 01, 2012 | GE Americana A4425GDTWW Side by Side...
My ge tfx30pp is not staying cold after running it on a generator for a week
Is the compressor kicking on and off? Is the freezer working OK?
Nov 14, 2011 | Refrigerators
Refrigerator not cold, freezer barely cold and has ice on back wall
You have a defrost problem if the ice is on the back lower wall of the freezer section.... This is where the evaporator is located just under a fan.(aluminum coils looks like a radiator) There are three parts to the automatic defrost system- the heating element(found at the bottom of the evaporator) a bi-metal thermostat(found at the top of the evaporator) and a defrost control board(usually in the top of the refrigerator section,but this varies)
If you take off the back freezer panel and melt the ice build- up with a hair dryer or letting it open overnight, without poking any holes in evaporator and losing freon(out a fridge) your fridge will run fine for about 3 weeks. This is humidity from air collecting, automatic defrost system usually works about every 8 hours when working normally. Your sealed system and compressor are fine, you have a defrost problem. Good luck.
Mar 14, 2010 | Maytag MZD2766GES Side by Side...
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Icing in Freezer Compartment
Hi!! your drain line is plugged its inside your freezer compartment. look at the back wall on your freezer and fins you see is called evaporator try to remove the cover and get a hair dryer and melt all the ice that you see in the bottom portion of the evaporator..you should see a small hole at the bottom of the evaporator that your drain line unplugg it..Or you can do it the old fashion way just turn it of complete for 2 days and all is fine..Good luck..
Jan 04, 2009 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
183 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
