Question about Recoton Advent Advent Q2035A 20" TV
My monitor resolution is stuck on 1280 x 1024
My monitor is on 1280 x 1024 but needs to be on 1440 x 900
was working fine but i cannot get the monitor to 1440 x 900 ? the gfx is set to 1440 x 900
  • 729 Answers
You need to install the EXACT video card driver. what was currently installed driver might just be the compatible driver.
Posted on Jun 04, 2009
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
Lg 29" monitor vga setting won't go to 1920 x 1080
If it was fine then you did something like changed connectors, cables, video card. VGA will not do that high a resolution.
Mar 30, 2014 | LG Flatron W2242TQ-BF 22" LCD Monitor -...
I have a matrox millenium g450 DVI PCI graphics card but it is stuck on 640x480 or somewhere around that resolution so it cant display on my monitor, what do i need to do to fix it? I connect it using a...
Ryan,
Sounds like a nice setup you have going there, but the TV is going to be fussy about resolution. You need to plug in a regular monitor to adjust the resolution to something higher than 800x600, preferably 1280x720, make sure the screen comes back up on the monitor, then reboot the computer with your tv plugged in.
Please let me know if you have any more questions.
Thanks.
Mar 22, 2011 | Matrox G450 Millenium 32MB DDR PCI Dual...
Hi, I have a problem right now i have resolution 1080 but there are some vertical stripes and i don't udnerstend all words, with resolution 1900 that stripes will vibrate, resolution 1024 do not work...
Try to check the power supply some capacitor may worn out, or your main board need to be re-soldered, check if all connector were intact. Contact service personnel to do it for you.
Jan 14, 2011 | LG W2253TQ-PF Monitor
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to http://support.gateway.com/support/default.aspx input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Sean
Mar 16, 2009 | Computers & Internet
Hp Pavilion Monitor
Monitor was working then I downloaded a game and got the warning message to change the resolution. I changed it and now my monitor is stuck in black. What can I do now?
Dec 03, 2007 | HP Pavilion F1703 17" LCD Monitor
Recoton Advent Advent Q2035A 20" TV Logo
117 people viewed this question
Top Recoton Advent Televison & Video Experts
Jaime Hernandez
oodio
oodio
Level 1 Expert
Jason Morris
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
