Question about Sharp AR-5320 Black and White Copier
SCREEN BLINKING L2 ON SHARP AR-5316 E
WE JUST TURNED IT ON THIS MORNING AND THIS STARTED
  • Sharp Master
  • 1,294 Answers
L2 mirror sistem problem.Check mirror motor and mirror home position sensor.
Posted on Aug 02, 2009
    President:
  • Sharp Master
  • 1,447 Answers
It is problem your copier scaner sansor clean it then solve your problem
Posted on Jul 15, 2009
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
CODE ERREUR U2 appear on screen sharp ar 5316
press # press INTERUPT press C press INTERUPT then put 16 then start then press clear after that the machine will turn off and agin
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
My Copier Sharp AR-5316 is not working, it is blinking U & 2, and the machine is not working, please help. Sorry for my language.
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 16 and start key twice
Hope it helps,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
-COPIERS - AR-5316 Advanced Digital Imager Copier: i m not getting the printer driver of sharp AR-531...
The printer driver comes on installation CD when buying a new copier. If you are using it as a printer, insert the CD inside the CD-ROM drive and click open the file written set-up and follow on-screen menu. Connect the USB cable when prompted to finish your installation. Now you can print using your Sharp AR-5316 and that is the driver for it.
May 18, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
My Sharp - COPIERS- AR-5316 keeps blinking 4 immediately i power it.
if Your copier is 4H blinking it is over heat
C# interrupt # and then 14 start key 000
Mar 05, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
