I am having problem with my computer at startup like it is showing only desktop wallpaper but no icons and no task bar and no start tab so waht should i do?
  • 749 Answers
The user account responsible for that is corrupted... try booting the computer and press F8 at start up and try "System System Setting that Work Fine" some thing like that or also you can try the "Safe Mode" to try to restore your desktop... It this does not work, you needed to refresh the windows setup... you need to have a Windows Boot disk to do this and reinstall windows without formatting it... the operation it does will restore windows, all files are not changed.
Good luck!!!
Posted on Jun 04, 2009
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
My Hp-620 Laptop is not displaying Wallpaper and no option for it pls help me
Do you mean your laptop shows no start menu, no desktop icons? If its seems like it booted up except nothing is shown on the screen try the steps below.
Click Ctrl+Alt+Del to get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hit the Del key while holding them. Once the task manager opens Clcik the Processes tab then click the Image Name Column heading on the left to get them in alphabetical order. Scroll down and look for explorer.exe. If you see it click it to highlight it then click End Process.
Next, click the FILE tab at the very top left of the window and select New Task (RUN). When the Create New Task window opens type explorer.exe and press ok. Your start menu, task bar and desktop icons will start appearing and populating. if not that means a virus has hidden your files and folders.
If it is not resolved try the steps below:
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 06, 2012 | Computers & Internet
Dell - No icons or start button
to get your Icons back try this.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
I would also try this.
Another quick shot, is goto Start, Run, type "msconfig", and click the tab saying DIAGNOSTIC. click apply, restart, and see if your icons are there.
Then I would run a virus scan. you could have a virus on the machine. I recommend MalwareBytes for virus removal. you can get it at www.Download.com
Jan 11, 2010 | Dell Computers & Internet
On my pc not any icon or start menu can be shown only wallpaper can be here
To solve this issue..
1) Click CTRL+ ALT + DEL at a time..
2) You will find Task manager option..
3) From that select process tab..
4) Then select explorer.exe...  And select end process..
5) Then select application tab...
6) And click o new task..
7) In the bar type explorer.exe..
8) Then select ok..
Now the icons will be reloaded.
Jan 02, 2010 | Microsoft Windows XP Professional
No icons or tool bar on desktop at startup
In your desktop, Right click your mouse and properties will show and look for show desktop option. And then move your mouse to the bottom of your computer screen, if toolbar will show, then your toolbar is set to automatic hide. Change the settings in your Taskbar and Start Menu Properties and change there the settings, uncheck the auto hide task bar.
Nov 10, 2009 | Acer LX.W530X.012 Gateway M7325u 15.4in...
Ok on my macbook pro it seems to have locked up i see the task bar but the icons or nothing else will show up any soulution?i tried apple option esc but nothing showed up. it seems to lock up where i can...
Hello
This can be hardware or software related...
If you can see the dock, it means that the system started up with success, but had a hard time to get your account running.
You should try these:
- Press the shift key at startup for 15 seconds at the startup chime). this will check your hard drive, and deactivate extensions. it will ask for your password.
- If you see your desktop, and the apple, then go to the apple menu - system preferences - accounts -startup items tab. Delete all the startup items
- If it did nothing, the you should try to boot from your OS DVD pressing the c key at startup, abd repair the disk's permissions here
- At last, reinstall your system, choosing the "archive and install" option when requested
Hope this helps
Jul 13, 2009 | Apple MacBook Pro Notebook
Icons and start upmenu bar absent
explorer.exe is what displays the icons and the startup bar on the screen so try opening explorer.exe from the task manager. Or if it is already running close it and then reopen it.
Jun 08, 2009 | Computers & Internet
Explorer doesn't start
go to Start > Run > msconfig
In General tab
make sure you are set to Normal Startup.
Mar 18, 2009 | Microsoft Windows XP Professional SP2 for...
Start Task bar not showing
Press the Windows key to open the Start menu, then right-click the start button and choose properties.
Next, go to the task bar tab and
1. Uncheck auto-hide
2. Check keep task bar on top of other windows
Dec 11, 2008 | Computers & Internet
Dear Sirs I have just insalled the SimpleCenter media but I do not want the icon to automatically load onto the task bar on the right hand side,although I would like the shortcut to remain. I can delete...
You cannot delete the icon from the task bar as it only displays the start up programs running on the computer. I have given the steps below.
Click start, than click run. In this box type "msconfig" without quotes.
You will see the list of startup programs. Uncheck the ones related to the Simple center Media.
Click Aply, Than click close, than click Restart computer now.
The program will not load automatically and you would not see the icon in the taskbar.
I am sure this will help. Please update me on the same.
Regards,
Sammy
On Top of the window click startup
Jul 10, 2008 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
