Question about Sharp MX-3501N All-In-One Printer
Data ligth keeps flashing intermittently and need to reset machine..?can it be a Hard Drive problem perhaps?
    Sergeant:
  • 199 Answers
Possible cause of HDD bad sector or softwere error also check if there are any loose connection between print board & dc.
Posted on Jun 04, 2009
Pls . help me experts , i have kyocera km3050 copier but the lcd touchscreen is not responding but days past when it still responding its getting hard to respond. please help me with this experts
A hard reset can clear minor error codes. A lot of times you do not really need to call for your support contractor. Sometimes errors stop the function of a machine, but the machine could still function properly with a hard reset. Perhaps there is a better description than hard reset, as "reset disable function" is a little bit confusing and not a phrase you were likely look for.
Contact your service provider before following these instructions.
Use at your own risk. Perhaps there is a possibility of causing damage. Again, contact your provider.
From our copier service company:
This reset is used for two purposes:
1) reset any data that may be "hung up" in the hard drive.
2) reset an error code and attempt to continue use. (If the error recurs, then you should escalate to whomever supports the copier.
Hard Reset Procedure:
Press Status button
Enter 10871087 - You are now in Maintenance Mode
Enter 906 (do not enter any other numbers!)
Press Start
Press Execute
Press Start
Copier tells you to turn it off/on
Turn off power by switch on right side of copier (hard power off)
Turn on power by switch on right
I have seen to use code 163 instead of 906. I don't know what this does. Again, consult experts before using this code or any others.
Feb 03, 2015 | Kyocera Mita KM3050 Black Toner Cartridge...
Screen locked and alignment wrong
To restart, press and hold the on button on the upper right of the device. Select 'Restart' from pop-up menu.
Not sure if you can recalibrate your screen.
If all else fails, perhaps you can try hard reset:
http://hard-resets.com/hard-reset-asus-memo-pad-hd7/
Try if you can avoid wiping data by selecting option not to wipe.
Apr 21, 2014 | ASUS MeMO Pad HD 7
Iomega Prestige Portable Hard Drive 500 GB External hard drive blue light keeps flashing and clicking at same time/
This hard drive is faulty and the clicking sound is known as the "click of death".
If you need to recover data from this hard disk, there are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Mar 19, 2011 | Iomega Computers & Internet
My SanDisk Cruzer USB flash drive had problams with the U3 systam, So i uninstalled it by using the "renuve u3 luntch pad.exe." then I selected the "format adn keep my data" option, but the systam find a...
You have ruined the file integrity of the flash drive, There is a very slim chance that you will recover any data off of the drive. Most flash drives only have a read/write of about 8,000 to 9,000 times so depending on how much you actually used the drive, it is possible it finally went bad. To format the drive try going to my computer and right clicking on your cruzer drive letter and click format. "ALL DATA WILL BE ERASED WITH THIS OPTION"
Jun 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My lg kf750 secert has no sound. I have checked volume. When the phone rings there no sound and i can't hear person on line but they can hear me.
Firstly, try to go to 'Menu > Settings > Reset settings'. This will clear only your personal preferences, thus not touching your applications or personal data. However, ff you keep having problems with your sounds, perhaps a hard reset could sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all programs you have installed, as well as your personal data. To perform a hard reset, turn your phone off completely, by pressing and hold the power button and answering to the prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue. When your device powers up, it should be completely clear now.
Hope it works for you, since this is pure theory. I have never done it myself.
Cheers! Carlos
Apr 17, 2010 | LG Secret ? KF750 Cellular Phone
Low beep sound and try on a pc also can not detect it
Unfortunately, they are designed to void the warranty if opened. But since you mentioned trying different PC's, how about different USB cables, or perhaps a duplicate power supply, perhaps one of these items is the issue. There may be a software issue, in that instance if you can find an imaging program, like Acronis, or Macrium, they may detect the drive and **** the info off of it, in order to get any different results that windows the imaging programs will need to run off of "bootable media"
Apr 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My pc havet a drive for my flash memory
If you want to format to remove all the data from your flash drive and wipe it clean you do not need a program as you can do it through windows.
Step 1 - Plug in your flash drive to a working usb port Step 2 - Click on start and then click My Computer. Step 3 - Find your memory stick. In most cases drive C is your hard drive and drive D is your disc drive. This means that your memory stick is most likely drive E. It is a removable storage device and not your hard drive. This is very important because you don't want to format your hard drive. Step 4 - Back up any data you want to keep from your flash drive. When you are done with the formatting everything will have been removed from it. Drag the files you want to keep from your memory stick onto a folder on your computer. Step 5 - In your My Computer folder right click on your flash drive icon and click format.
Mar 18, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Seagate Free Agent DeskTop 750 gb stopped working
Good day maam, hi, sorry to say this but, you lost your hard drive already. You lost your Files to. There are slim chances you need to pay for HArd drive recovery, this are offered by some private company check out this website: http://www.harddriverecovery.org/
Dec 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My book reset button
how do you remove the battery? how do you open this thing?
Dec 11, 2007 | Western Digital MyBook Pro WDG1T5000 500...
Sharp MX-3501N All-In-One Printer Logo
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
