Question about Ovens
OVEN & COOKTOP - DANIELA ~ NO MODEL ON IT.. NEED SWITCH INFO
Hi we have the above and want to know which is the grill on the dial, there's 4 selections on this dial, i know this will be trickie cause there's no model number anywhere on cooktop or oven.
gas cooktop, fan forced oven, 3 dials at front, 1st on LHS is timer, middle/2nd is the 4 settings inc. grill, 3rd dial RHS is temperature.
HELP HELP HELP..
thank you debbie
vest6
  • 196 Answers
SOURCE: smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Posted on Jan 26, 2008
SOURCE: Ariston underbenchoven - Model FM81R
I also have a copy of the manual
Posted on Sep 14, 2008
SOURCE: How do I set the time on our oven??
how do i work the timer oven turns itself off after 10 minutes i guess its set on timer have no instructions it flashes letter A top left corner
  • 20 Answers
SOURCE: SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Posted on May 21, 2009
SOURCE: Faulty Daniela oven
Hi Fiona, here is the service department number 1800886010 or the manufacturers number is 0296041226
Hope this helps
Pam
Posted on Oct 23, 2009
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
I turn on the top oven and the grill element also comes on. I can grill ok but I cannot use the top oven for baking. Any advice please?
Hello;
My name is Peter. i am a retired field service appliance technician.
It sounds like you have a bad control. I can not be sure of this because you did not proved a model number so I can see what you have
Sometime these components are inexpensive and easily replaced.
You model number is on a metal plate on the upper face of your oven after you open the oven door.
May 12, 2015 | Ovens
Oven, clock, timers all work, but grill & cooktop do not function Jenn Air Model SVE87600
Check the back and make sure the wiring to the grill cooktop is not unplugged from the main oven.
Nov 04, 2013 | Ovens
I need a users instruction manual
Can you tell us the make and model?
Apr 08, 2013 | Ovens
Faulty Daniela oven
Hope this helps
Pam
Sep 25, 2009 | Ovens
Lettering missing from dials - what should they read?
How do I know if a handy man with a liscenceBakersfield Ca
Aug 07, 2009 | New World Ovens
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
AEG Oven
try setting the clock, it may be automatic
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Ovens Logo
391 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
