Question about Samsung 793S 17" CRT Monitor
Monitor problem Monitor starts out very dark so you can't see anything, but gradually getting lighter until it has a beautiful picture but keeps going lighter until completely faded out and then flips back to black again and keeps repeating. When i turn the monitor off it starts at black again when i turn it on and i have a limited time to see until it goes black again or fades so much i can't read anything.
  • hazemawad Feb 16, 2008
    samsung syncmaster 793s moitor, bjack screen,hardly to see or read any thing on it i ceck for reulator 12v and 5v it is ok,, where you sugest is the proplem?
  • diva_vikki2 Jul 30, 2008
    monittor go black i have to keep turning it on and off it only stay of for a few minutes at a time my monitor is a proview
This problem came from CRT base Pl change CRT base
Posted on Feb 19, 2008
    Scholar:
  • 116 Answers
This monitor is bad replacement is the only option as the CRT monitors are obselete you could get a good deal on one if you are not shopping for a flat panel!
Posted on Nov 26, 2007
SOURCE:
Viewsonic N3240WB-E top 3'' of picture has gone dark
From the description one of the backlights behind the display is failing, and cost would not justify the expence, you are further off replacing the monitor
Jul 09, 2012 | ViewSonic Computers & Internet
I GOT NEW PC BUT ON OLD PC MONITOR WOULD COME ON DARK THEN GRADUALLY BRIGHTEN UP BUT THEN AFTER IT WAS FINE I THOUGHT WAS MY PC CUZ WAS HAVING TROUBLE WITH THAT AS WELL BUT WHEN I HOOKED MONITOR UP TO...
The 204B monitor have a known issue with power supplies that start failing and you get the "slow to show picture" problem just like you have. The monitor is very easy to repair and the parts are low cost. Here is a link to our repair guide http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ If you can solder then you can fix your monitor. If you don't want to repair it contact me and we may be able to buy it from you for parts.
I hope this helps, if so please rate my solution.
BuddyMc
tech@ccl-la.com
Aug 06, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204B screen appears in 5 min after turning monitor on. First 7-10min screen is dark and slowly increases brightness. The picture becomes normal in 15-20 min and all is OK until the monitor is...
How long have you had the monitor. It sounds like a defective backlight. Usually when the circuit driver for the backlight starts to go bad, the monitor will blink. If this is the case, eventually the monitor will not turn on at all.
Jan 12, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
Display is very dark seeeems to gradually worse. Problem started after win7 install
Tried connecting the laptop to an external monitor and press fn f8 and let me know if you get any picture? If you do you need to replace the back light inverter or the screen.
Thanks,
Dec 18, 2010 | Acer TravelMate 4021WLMI Notebook
I've started having this problem with the SyncMaster 730 monitor a few months ago. Every time the computer was booted up or came back from an overnight screensaver or sleep mode, it would come back all...
Look for bad caps. http://s807.photobucket.com/albums/yy352/budm/Samsung%20730B/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 18, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Black then gradually disappear in crt mointor
This problem needs a professional service technician,the problem could be on the picture tube/CRT or the ply back.
Sep 13, 2009 | LG Studioworks 775N 17" CRT Monitor
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
AOC spectrum 7 Glr ?
Initially, I would suggest that you do a full reset, that is unplug the monitor from the mains and the PC for a couple of hours (preferably overnight). The idea is that the monitor will reset itself to default factory settings. Thereafter try again.
Should problem persist, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 12, 2008 | AOC LM729 17" LCD Monitor
Monitor too dark
To get a refund you need to send an email to experts@fixya.com.
I would like to add that troylove11 is absolutely right.
Dec 29, 2007 | CTX S762A 17" LCD Monitor
Samsung 793S 17" CRT Monitor Logo
197 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
