Question about RCA D52W15 TV
Cable connector repair
The connector on the TV for the cable has gotten pulled off.  can I repair it or is there a way to by-pass it.
  • wado1 Mar 25, 2008
    The RF connector on my D52W15 has broken off so I would like to know how to repair it.
    Genius:
  • 1,694 Answers
Best repair is replace tuner. Next is replace broken connector.
Use generic RF input connector from supplier such as Mouser
Electronics or RCA part # 215543.
Next - By-pass would need a source box ( cable,satellite,vcr),
           in other words, channel change ability . Hook cable-in
           to source then go out to TV video input.TV would stay
           on video input as a monitor........T.
   PS. If you want the tuner part # , please provide service # from
          back of set....
Posted on Oct 26, 2007
  • Vista Electronics Oct 31, 2007
    Please rate my solution.....Thanks.....T.
  • 20 Answers
Use RCA cables instead of ch 3
Posted on Oct 24, 2007
Automatic transmission shifts down on its own
the kick down cable must have slack, at idle.
if not its bad. (end to end, something is wrong with it)
this cable is for passing gear.
you jam the throttle and the tranny then down shifts.
called, kickdown, detent and TV cable.
if the cable rusts it can in fact rust , pulled. and now in passing gear full time. or it can stick driving do to rust.
what i do is make sure the trans, end of cable the detent rod is not sticking, if that is ok, , get a new cable.
Mar 15, 2014 | 1997 Jeep Grand Cherokee
Video cable pulled out
Yes. The connector on the tuner is probably pulled out. Depending on your skill or the skill of the repair person and the amount of damage...it MAY be repairable or the entire tuner board may have to be replaced.
Apr 23, 2010 | Sony Televison & Video
The CATV connector on my Mitsubishi tv is broken off
This is the connector for the tuner. This repair must be done by someone who knows how to solder. But, if you have a Cable or Satellite box and this TV has AV connectors on the back....you can use those and do not need to repair the TV tuner. If you do not have cable or satellite you can also use a VCR as a tuner. Just put the cable into the VCR and come out of the [VCR] AV outputs into the TV AV inputs.
Jul 06, 2009 | Televison & Video
Coaxial connector broken
I have a magnavox plasma 50", when i remove it from the table i forget to unplug the coax cable from the back of the tv so i pull the connector out from it, anyone tell me what can i do to repair or replace this solution?
Jun 04, 2009 | Philips Magnavox MT1905B 19" TV
Broken cable connector
Yes this is a cheap fix that should only cost between 15.00 and 25.00 US if you take the TV in to be repaired! dont have them come to your house as it will cost much more!!this can be fixed in a few minites so dont let them take advantage of you!
Please rate my response to your question!
Feb 02, 2009 | Recoton Advent Advent DV1418A 14 in....
No remote control response (toshiba 42h81)
Are you SURE the cables are right?? The cable for the remote sensor and the speakers are both 4 pin and can easily be swapped. The cable with the brown wire (speakers) will attach to the convergence/signal PCB on the far right edge, while the remote connector plugs into a connector closer to the center of this board.
Jan 02, 2009 | Toshiba 42H81 42" Rear Projection...
We picked up a tv at a yard sale and the part where you connect the cable to has been pulled out. Is this repairable?
Good Day;
This is normally replaceable if the PC board was not damaged. The 'RF' connector is a soldered (crimped) on item. But don't despair; most projections that I now of have video inputs of some type.
If you have a cable, sat box or VCR you can bypass the connector by using 'RCA' cables. On one of the mentioned above devices hook the cable from box to TV. The 'box' will have a video output connector and the TV will have an input connector. The cables are color coded yellow (video), red and white (audio). Switch TV's input to correct input eg. input one, input 2.
Respond back @ mmrkcar@yahoo.com for more person to person information. Good Luck, Big Irish.
Jun 18, 2008 | Televison & Video
Cable cord connector
Greetings Florie12,
This unfortunately is a common issue that happens when moving televisions with the coaxial connection (the silver connector). Normally the best way to get this repaired is to bring it in to a local repair facility. I can't speak on the costs but they should be nominal, as long there wasn't any other internal components that were damaged.
Another repair option might be to purchase a digital converter box for your television as long as you have Audio/Video inputs. With the pending conversion to digital broadcasts this would be killing two birds with one stone.
Cordially,
Jon
Go Ahead. Use Us.
Jun 17, 2008 | Panasonic CT-36D32 36" TV
TV Cable connector issues, Evil Dog
but is the TV still repairable? yes it just a simple problem call tech he will do it at your home in a short time.
May 04, 2007 | Sanyo AVM-3659S 36" TV
Cable Connector inside TV
Unless you know how to sholder well and know how to do an isolation test on the set after its repaired I would let a pro do it My friend as I've seen it a hundred times. A peep will simply hook up a connector to the set and ground the connector or what looks like a ground and as soon as that set is pluged into an ac outlet and a cable or sat line is attached KAPOWWWWEEYYY.. It smokes and you end up blowing out the bridge rectifiers aong with all sorts of things. Now dont get me wrong please as you can repair set if and only if you wanna take that chance by simply taking a piece of coax cable with a connector on one end and soldering the center wire onto the broken wire that came off the connector and then soldering the outside or sheild wire to the place where the broken connector was attached if at all possible BUT I repeat this is not a good way to do this. Good luck
Mar 23, 2006 | Sanyo DS31590 31" TV
RCA D52W15 TV Logo
484 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
