Question about Sony VAIO VGN-NR220E/S Notebook PC
I resently instled windows surfice pac 3 the pc sounds went of and the monitor resolution is not full
    Genius:
  • 2,785 Answers
Plz try by reinstalling the drivers
Posted on Jun 04, 2009
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
After opening several windows screen will go black and freeze momentarily and then go back to windows page
1. sounds like your monitor is losing power
2. the windows video driver needs to be updated
3. Video resolution mode not supported by monitor...
Please give feedback
Dec 18, 2012 | Dell Dimension 8300 PC Desktop
Very dark screen in full screen mode
Check the monitors native resolution (you can get it in their website's technical specification area and set the same resolution in your windows resolution.
Jul 22, 2012 | Dell Dimension 8400 PC Desktop
Attention autoconfig please wait -- this message keeps popping up in the monitor continuously. it also adjusts the contrast anf brightness some times automatically. please help
Sounds like the "auto config " is built in to your monitor. It selects screen sizing based on the resolution, sync timing, refresh rate, etc... that your video card is adjusting on the computer.
I would suggest you to try changing the resolution in Windows and see if still receive the alert.
For more information on Screen resolution and display on monitor, check the below Microsoft Help & How-To Articles:
1:
Change screen resolution :-
http://windows.microsoft.com/en-us/windows-vista/Change-screen-resolution
2: Getting the best display on your monitor :-
http://windows.microsoft.com/en-US/windows-vista/Getting-the-best-display-on-your-monitor
3: Troubleshoot monitor and video card problems :-
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-monitor-and-video-card-problems
If it is doing it often and you are not changing screen resolution I would say the monitor itself might have issues. It's possible your display driver may be corrupted. I would suggest you to download and install the latest drivers for the Monitor from the manufacturer's website.
For more information on Updating a Driver and fixing driver problems, check the below Microsoft Help & How-To Articles:
1: Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows-vista/Update-a-driver-for-hardware-that-isnt-working-properly
2: Tips for fixing common driver problems
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-driver-problems
Check the plug and cable, look for bent pins or pins pushed in.
Are you using one of those DVI/VGA adapters? If your monitor has dual inputs (DVI & VGA) have you tried using the other input?
Anyway you could check if the issue exists when the monitor is connected to another PC? Or maybe try another monitor on your PC?
source: answers.microsoft.com
Mar 12, 2011 | Computers & Internet
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Regards,
KYTechnology
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
SYNCMASTER BM SREEN WILL NOT ACTIVATE JUST A FLOATING SQUARE BOX SAYING NOT OPTIMUM MODE RECOMMENDED MODE+ 1280x1024 60hz analog
I tried the following options and neither worked. 1) Hitting the monitor buttons as stated only got me a "digital" message and then the monitor went black as usual. Never got to any menu options. 2) Going into Safe Mode and changing the monitor settings or downloading/installing the correct driver didn't stick once you went back to the normal startup.
I didn't have another monitor handy to swap out so I had to be a little more creative. The only solution that worked for me is re-booting (F8 during startup) into the mode "Enable VGA Mode". This allowed me to go into the normal desktop with a screen resolution of 800x600. I went online, found the driver, downloaded it to the desktop. Deleted the video driver (Device Manager), installed the downloaded version, rebooted and....no problems.
I have Windows XP. Hope that helps. :)
Jun 06, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
I have a new flat panel 21" monitor which I love. However, photos which I took of taller objects and some Windows games appear too wide and not tall enough. The same thing can happen on the new TV's when...
It sounds like you have the resolution set wrong. Typical monitors are setup with a 4:3 aspect ratio. With the widescreen monitors, you have to get a resolution that will support the 16:9 I purchased a dell monitor a while back that was the same way, and I just went in and made sure I had it set for the 16:9 aspect ratio.
Right click on the desktop, go to Personalize(Vista) or Options, and then system tab, and slide the bar along the resolution ruler to the correct size. Play with them a little too, to make sure it fits you best. Some of the higher resolutions will show more screen space, but will have smaller text.
Mar 15, 2009 | HP w2558hc 25.5" Widescreen LCD Monitor
HDMI green screen
1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
The type of cable used and the inputs available on the TV or display monitor.
The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
How to Adjust the sceen ratio from 16:9 to 4:3
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Aug 05, 2007 | Philips 190CW7CS27 Monitor
Sony VAIO VGN-NR220E/S Notebook PC Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
