Question about Dell Latitude D600 Notebook
Server taking too long
Pinged hotmail
request timed out x 4
sent 4 received 0 lost 100%
pinged yahoo
replied x 4
sent 4 received 4 lost 0
avg.70 ms
same on all my laptops & desktops cannot get through to random sites
  • 197 Answers
If you are using a wifi - update your wifi driver
if your are using a network cable - update your network driver
Posted on Jun 05, 2009
My computer is showing that it is timing out when I do a ping command. This then freezes my Citrix apps that I have to use for work and I can't work. Is there a firewall blocking the connection?
First question, why are you running a ping? do you have a problem connecting to your Citrix apps?
It is very probable that your work is blocking ping for your Citix server.
If you want to find out *where* the blockage is try a trace route
tracert (destination address\ hostname).
Some blanks are to be expected as most Network suppliers don't reply to pings either,
so for :
tracert www.bbc.co.uk
but you should get something like :-
1 3 ms 3 ms 3 ms routerlogin.net [192.168.0.1]
2 * * * Request timed out.
3 18 ms 17 ms 18 ms nrth-core-2a-xe-825-0.network.virginmedia.net [62.253.128.105]
4 * * * Request timed out.
5 26 ms 124 ms 37 ms brhm-bb-1c-ae1-0.network.virginmedia.net [62.254.42.210]
6 23 ms 24 ms 27 ms tcl5-ic-2-ae0-0.network.virginmedia.net [212.250.15.210]
7 24 ms 80 ms 22 ms 212.58.239.249
8 * * * Request timed out.
9 31 ms 38 ms 33 ms ae0.er02.cwwtf.bbc.co.uk [132.185.254.90]
10 21 ms 28 ms 38 ms 132.185.255.165
11 27 ms 31 ms 25 ms bbc-vip046.cwwtf.bbc.co.uk [212.58.246.55]
Nov 20, 2016 | Computers & Internet
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
I have installed dlink 1016 10/100 Switch I have two computers and one dsl router connected to this switch but i am facing slow internet problem. when i connect my pc directly with router it works fine...
you'll probably find the router is set up to ignore ping requests, most are by default, for better results, try pinging a website and compare the results both with and without the switch. The switch shouldn't make any noticable difference to your connections, I use one and there's not perceivable difference in performance.
Apr 19, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
Hello sir. my voice call is not working, You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal. every...
It is because your internet connection is not good stable or not good enough for making voice calls...
To check this, Click on Start >> RUN... Type CMD and click on OK.
In Command Prompt, type ping 4.2.2.2 (space after ping) and press enter
it will give you result like this:
C:\Users\abhishek.tripathi>ping 4.2.2.2
Pinging 4.2.2.2 with 32 bytes of data: Reply from 4.2.2.2: bytes=32 time=309ms TTL=57 Reply from 4.2.2.2: bytes=32 time=275ms TTL=57 Reply from 4.2.2.2: bytes=32 time=276ms TTL=57 Reply from 4.2.2.2: bytes=32 time=275ms TTL=57
Ping statistics for 4.2.2.2: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 275ms, Maximum = 309ms, Average = 283ms
If you get 4r replies, than your internet connection is fine. Is any of the line says "Request Time Out" then it is clearly a problem with your Internet Connection.
Apr 12, 2011 | Yahoo Messenger
Have a D-Link EBR2310 How can I test it to see if the port to the to the computer is working? The port gren does not light.
You are saying you cannot connect through the router ... Change the ethernet cable and/or try other portson the router.
Does your computer connect to the WWW when you wire it directly? If it will work when connected directly then it should work through the router. That is your test.
Thanks for your interest in FixYa.com
Please vote
a
Dec 03, 2009 | Office Equipment & Supplies
HI...since yahoo mail went down monday i cant get on any part of yahoo at all.......Why? thx Hellsvampbiker
I don't recall Yahoo going down on Monday, but it sounds like you might have a virus that changed your HOSTS file, which is an override for websites. Here's a good way to check:
1. Hold down the Windows logo key and press "R". A dialog box will pop up.
2. Type "CMD" without the quotes and click "OK".
3. You will see a black box appear. In that box, type "ping www.yahoo.com" without the quotes and press enter.
It will take 5 seconds for a successful test looking somewhat like this:
Pinging www-real.wa1.b.yahoo.com [XXX.XXX.XXX.XXX] with 32 bytes of data:
Reply from XXX.XXX.XXX.XXX: bytes=32 time=56ms TTL=57
Reply from XXX.XXX.XXX.XXX: bytes=32 time=53ms TTL=57
Reply from XXX.XXX.XXX.XXX: bytes=32 time=51ms TTL=57
If it cannot get to yahoo, it will take about 10 seconds and look like this:
Ping request could not find host www.yahoo.com. Please check the name and try again.
OR
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for XXX.XXX.XXX.XXX:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
If it cannot find Yahoo, navigate to C:\windows\system32\drivers\etc and look for a file called HOSTS. Rename that file to HOSTS.old. Once you've renamed the file, try to ping yahoo again. You should get a response, and you should be able to access yahoo.
If you need more troubleshooting help (if this doesn't work) send me a message and we can try some other steps.
Oct 29, 2009 | Compaq Presario Notebook
IE unable to open web pages
The version of IE does not matter.
Click "START"
Click "RUN"
Enter 'cmd' and press ENTER.
Enter 'ping www.yahoo.com' and press ENTER.
Do you get output like:
Reply from 209.131.36.158: bytes=32 time=81ms TTL=56
Reply from 209.131.36.158: bytes=32 time=37ms TTL=56
Reply from 209.131.36.158: bytes=32 time=44ms TTL=56
Reply from 209.131.36.158: bytes=32 time=61ms TTL=56
Ping statistics for 209.131.36.158:
If so, then your Internet connection is working fine.
If not, then you have no Internet connection.
Apr 22, 2009 | Dell Inspiron 1720 PC Notebook
Network Timeout error.... Going crazy! Up until about a week ago, I was able to access www.packratwiki.com without a problem. Now, I am getting a network timeout error. None of the computers in my...
Hi
I am assuming that you are using a router/firewall for your home network which is hooked up to your modem or probably a combo of both. First of all if the problem persists you have to make sure that your firewall / router is not blocking this IP. In order to check this out ...
1. If it is just this site that you are not getting: download a program called ultrasurf. Install and see if when you provide the IP above and get the website to come in. I checked the website for you and it is online and working. So it is a local problem.
2. If it is all the sites you're not getting and you know how to configure your router, I would give it a go and reset it.
3. FInally: you have to add this site to the exceptions of your firewall so that he lets it throughOnce you have determined which one of the 2 problems is yours. Add the site to the exceptions of your firewall so that you don't stay using ultrasurf for browsing that site. By the way use google to look up the program i mentioned :)
I hope that I was of help to you :)
Jan 07, 2009 | Computers & Internet
Unable to load yahoo page ..
Sounds like a dns problem.<br><br>press "widows key (Has a flag printed on it)  r" then type "cmd" then type "ping www.yahoo.com"<br><br> it should give you something like this<br><br>Pinging www.yahoo-ht3.akadns.net [209.191.93.52] with 32 bytes of data:<br><br> Reply from 209.191.93.52: bytes=32 time=51ms TTL=49 <br>Reply from 209.191.93.52: bytes=32 time=53ms TTL=49 <br>Reply from 209.191.93.52: bytes=32 time=58ms TTL=49 <br>Reply from 209.191.93.52: bytes=32 time=51ms TTL=49 <br><br>
Ping statistics for 209.191.93.52:<br>     Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),<br> Approximate round trip times in milli-seconds:<br>     Minimum = 51ms, Maximum = 58ms, Average = 53ms<br>
<br><br> you need the 209.191.93.52 number.  (May be different on yours.) Now take that number and put it whrere you usually type www.yahoo.com in firefox.  If it works its a dns issue and it is usually the service providers end.  If it doesnt work then reinstall firefox.
Dec 03, 2008 | Mozilla Firefox
Dell Latitude D600 Notebook Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
