Question about Nokia 3110 Cellular Phone
How to reformat nokia 3110c ? it begings when sudendy restart then there are file and folders apear with Mb size but no files inside..help
  • 10,515 Answers
well u can reformat ur phone after downloading Nokia software updater from Nokia website.instal it to ur pc, den connect ur phone wid pc and update ur phone wid Online connection on.
But it would not completely format ur phone..For complete formatting u hv to visit customer care..
Thanks.
Posted on Jun 04, 2009
3110 when switch on immedetly shut downWhat's your problem?
Nokia 3110c can frequently corrupt it's firmware (software).This problem can happen when we use mmc size of more than 521 MB because according to Nokia only 512 mb is supported.Or if the files in the mmc is infected by virus,or stored too much files in phone memory.The following things are related to this problem.So,to fix this you need to flash the phone, You can do it by following this Click here1. or contact mobile repairing shop.And here is your 3110c file .Good luck
Mar 28, 2012 | Nokia 3110 Cellular Phone
My nokia 3110c has an interrupted file in outbox. When i switch mobile with sim it immediately restart and it goes on and on. It can't be deleted. Plz help me.
Hi.To solve this you can do it by yourself.Click here1 and follow the instruction.Make sure that the important files/data which is stored in phone memory should move to sim or mmc because after you have done this all the file will deleted.(not for memory card).And remember if possible do not use memory card(mass memory) of more 1GB because according to nokia in 3110c only 512 mb cab use.Here is your 3110c file.Good luck
Mar 19, 2012 | Nokia Cell Phones
I use nokia 3110c. When starting music player it shows
You did not mention the error message but it seems that it was "no music files found".Here let give you the solution,first download and install Oxycube to your pc.Open the Oxycube interface and at the same time connect your phone via USB by selecting PC suite.After your phone is connected properly selec the C Drive of your phone which will be shown at the bottom of the Oxycube interface.Select the folder name "Hidden folder" and again there you'll see db music .....delete all the files with the pre-fix of db .Remove USB Restart or Restore your phone and open the music.If there is no other software problem this trick will perfectly work.But if possible before you Restart your phone scan the mmc or use mmc of less than 1GB.because according to Nokia 3110c supports only 512 mb of mmc.However,if this trick doesn't work the only solution is to flash the phone, so if you want to do it Click here1 ...and the flash file of 3110c file is here.Good luck thanks for visiting fixya
Feb 28, 2012 | Nokia Lands Phones
3110i nokia music softwer problam
Generally 3110c's software is very weak.If possible do not use memory card of more than 512 mb and do not store data in phone memory.You can solve this problem by yourself
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / if you need further assistant Click here1. thanks for visiting fixya. Good luck.
Sep 13, 2011 | Nokia 3110 Cellular Phone
Music player of nokia 3110c is not working.. plz help me.....
I thought that you were using the memory card of more than 512 mb.According to advise given by the NOKIA only 512 MB is supported.Now there is no other way other than flashing because music player may already corrupted.So, contact mobile repairing shop or follow the procedure given below
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/.Click here1. thanks for visiting fixya. Good luck.
Aug 30, 2011 | Nokia 3110 Cellular Phone
Nokia 3110C phone shut down and wasn't able to turn it on again.. it was just a blinking light.. how will i reformat the handset with the phone off?
No you cannot Format this thing..there is no other solution without flashing.So read carefully and do it
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gif Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 13, 2011 | Nokia 3110 Cellular Phone
Can u help me to format my nokia 3110c phone???
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Jun 29, 2010 | Nokia 3110 Cellular Phone
For jar files my mb. says file format is not supported !
Do you have the .jar supporter. For ex. for enablinh .rar file you need winrar. Like that do you have it. Please check it and reply.
Sep 07, 2009 | Nokia 3110 Cellular Phone
Nokia 3110c music player not working
my nokia 3110c music player updates continuously but does not start
Feb 09, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
867 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
