Need a printed copy of all wiereing details of this truck
SOURCE: 2001 dodge ram 1500 v8 spark plug wire diagram
the firing order is 1 8 4 3 6 5 7 2 clockwise around the cap
SOURCE: Need engine harness wiring diagram for 2001 chevy truck V8
The Best diagram you can get is at alldatadiy.com it has the sections and locations and color of wires with pictures.
SOURCE: vaccum hose diagram for 88 chevy truck
it may not be a vacumn leak from a line,check the throttle shaft for movement,for example,i had a 89 1 ton 350 and my throttle shaft was moving around a lot and in order to keep it from idling high,i had to kick the throttle pedal.But also check the idle air control valve,which is the round sensor on the side of the throttle body.
SOURCE: wiring diagram for a chevy truck
you can give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local GM-dealership in the parts department and they be able to print you off the pictures and diagrams you will need wish you the best of luck Michigan Man.
SOURCE: 2002 silverado 1500 wiring diagram
Look in your glove box and see if you have the PRO code U89: wiring harness, car trailer
It's common to have the trailer harness already installed in your Silverado without you know and the dealer can pull it out for you from where it's tucked up in the frame passenger side by the spare tire for the simple cost or $65.00.
http://www.etrailer.com/tv-wiring-install-2006-chevy-silverado.aspx
Thank you for using fixya and good luck.
