I want to remove deepfreeze software from my pc but i forgot the password
  • 739 Answers
Follow the path name to it's folder and delete the contents, an example is:
c:\program files\deepfreeze
I am certain there are more folders in the path. Active files will not delete this way, so you may have to use task manager to turn off the deepfreeze applications to fully remove the program
Posted on Jun 04, 2009
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
Pls help!i cant deactivate my deepfreeze accnt?i forgot my password or mybe somebody change my password.i badly needed your help,pls.thank you!ill wait 4 ur answer,tnx!
its a long process if you want 2 recover your lost password. I suggest that you should format your computer but remember 2 back-up your document. goodluck.
Feb 23, 2011 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
How to i can uninstail or remove deep freezee in my pc?
The best solution for this is to Disable with Anti DeepFreeze! You can get the two versions from this blog If you have forgot your pass or has been crashed then you can fix it with Anti DeppFreeze, You can get two versions free from this blog: http://deepunfreezer.blogspot.com/
Jun 19, 2010 | Amana 16.8 cu. ft. / 476 liter Upright...
How to delete deepfreeze
Hi. I think if that deepfreeze workstation program has password then you should know it and enter that password by pressing and holding CTRL+ALT+SHIFT then press F6 then enter the password. After that you must change the state to THAWED state then restart your computer. Your deepfreeze icon on the lower left should have an X marked now that is blinking, it means that your deepfreeze is already disabled, now you can uninstall it by using the same installer that you use to install your deepfreeze workstation. If you dont know the password you should have the main installer for deepfreeze 6 that creates a workstation installer and you can use that main installer to generate a password for you to login your deepfreeze workstation. Hope This Helps
Jun 04, 2010 | Computers & Internet
I forget the deep freez password and i want to uninstall deep freez but the dep freez are frozen. it is not disable
Oh!!
You have to Re Install your Operating System now. There Are no More Options left g\for your after forgot ting password. If you using license product then contact deepfreeze Devlopers to get help.
Thanks.
Happy to help you.
Apr 24, 2010 | Computers & Internet
I want to unistall my deepfreeze. I forgot my password.
download and install the software multi password recovery.most probably this will fix your problem of recovering your deep freeze password. the link is http://www.rapidshare.com/files/126452682/Multi_Password_Recovery_109.rar
Sep 17, 2009 | Computers & Internet
I cant remove the deep freeze software standred 6
read this :
http://www.faronics.com/faq/default.asp#7
1-This software (protection) is effective, it is
impossible to ignore, unless you remember
password entered at the first reboot after
installation password that allows you to unfreeze
the position, necessary step prior to
uninstallation. To access the password window
Password combine the ALT + CTRL + SHIFT + F6, then
choose "boot Thawed" and restart.
2-for Windows 2000 or XP
Go to Start-> Control Panel-> Tools
Administration-> Services
click on right click then Properties DFServEx
in the general tab in Startup type: select
Option deactivated
then reboot and all will be resolved
3-http: / / www.faronics.com/
4-for disabled deepfreez is simple
pressed the button shift + double click on deepfreeze
nearby clock. enter the code if you enter the / if you did
not click OK.ENSUITE CLICK ON BUTTON LE3EME
ENSUISTE OK and restart THE PC
after the boot up you found approximately one thinks red
deepfreeze ok
releancer installing deepfreeze and its SETUP
you found approximately UNANSTALL OK UNTIL THE END
AFTER rebooting TT WILL BE AS BEFORE
5-download the recent version of deep freeze and
installation and during installation it asks you
uninstall the previous version and continues to validate
jusqau he asks you to install the new version
cancel
Sep 09, 2009 | Computers & Internet
Problem of uninstalltion of deepfreeze software
use spybot s& d advance to remove this from your system
Feb 07, 2009 | Computers & Internet
Deepfreeze from my computer is not working properly
try uninstalling deepfreeze, it might solve your problem.. to uninstall deepfreeze, you must run the Installer file of deepfreeze..
Feb 03, 2009 | Ahead Software Nero 5.5 (NERO5.5) for PC
I WANT TO UNINSTALL DEEPFREEZE
I'm not really sure about the "DeepFreeze" software - but I do know that after months of me trying to remove a failed uninstall of Anonymiser software, that the only thing that could get rid of it for good was a program I downloaded from uninstaller.weebly.com
It really did work. The software makers also have a good support system, and they provide a way to email them the program details and they will do their best to investigate as part of the service provided with the software.
Hope it helps you - like it did for me!
Jan 15, 2009 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
