Question about Canon LASER SHOT LBP-5200 Printer
Says paper jammed but there is no paper jammed
  • Canon Master
  • 13,433 Answers
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 05, 2009
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Oct 20, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Canon LASER SHOT LBP-5200 Printer Logo
294 people viewed this question
old marine
old marine
