Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Trouble copying Our office primarily uses the MF6530 as a copier. The machine has turned out to be pretty bad. We are forced to use the side tray feeder, instead of cassette 1, because it wont pull the paper through from the cassette. But we have learned to live with that. The major problem is that now when we copy, the copier pulls paper through but the page is blank. I have checked the density settings, but they are fine. I'm not sure what else to try. The toner cartidge is relatively new, although I have taken it out and shaken it a bit, then put it back in. That shouldn't be the problem. It seems to be a scanning problem, in that it just doesn't see/scan the document on the glass. What could be causing this? Thank you very much for your time. -David
  • 4 Answers
Re: Trouble copying
Theengel is right, but fortunately there is a simpler solution, see below (I posted it 20 times I think because this problem is very common).
Reason : the shutter of the laser is not opened by the cartridge. (I had same problem, and solved it)
Open the door and remove the toner. look inside and you will see in the upper part a rectangular window in the metal bar. This window is shut by a metal plate behind when the door is open. Try to raise it with a knife. This is the problem. Now, this shutter is here only for legal reasons (security to prevent the laser beam going out when door open, but when the door is opened the power is shut so...). Cut a piece of plastic just the width of the opening, fold it at angle in the form or an L, then place it on the left side of the opening, so that the shutter can no longer go down. A piece of scotch to fix it in place and you are done.
Now, if it works and you are grateful, I am interested in empty cartridges.If you have some tell me. Thanks.
Posted on Dec 16, 2008
  • 121 Answers
Re: Trouble copying
When you close the door to the printer, there's something that opens the flap to the laser unit.  This makes it so the laser can shine down on the drum.  The flap isn't openeing when you close the door.  You'll have to look at the flap, and then follow all the mechanisms that eventually lead to the door.  There's a break in it somewhere.
Posted on Oct 27, 2007
0 characters
3 Points
Canon mf6530 shows "download connected."
you will need a service suport tool to rewrite the software on this machine.
It is necesary to contact a CANON tech to perform this operation, if you try to do it yourself you might damage it more.
Jun 06, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Canon MF6530 display says Download Standy
OK here is the deal: Either you can fix it easily by yourself or you can't. The manufacturer's suggestion is that you first turn power switch off. Then unplug the machine and wait for 5 minutes. Then plug it in and power it on. If that doesn't work try it a couple of more times and hopefully the machine will reset itself. There are variations of this method on line that incoude pressing a series of buttons in a certain order while the machine is powered off, but these are little more than electronic voodoo. If the manufacturer's recommendations fail it means that one of your circuit boards is gone and needs replacement. The good news is that if you saved your sales receipt and it's less than 3 years old, it's all covered under warranty. Happy Trails.
Jun 09, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Image print on paper slanting
Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
Jun 05, 2009 | Canon NP 6545 Copier
Copies are blank pages and doesn't indicate toner problem.
Bad lasrer shutter. There is a redesigned one going in warranty claim machines. the shutter can be removed but it breaks safty laws.
Apr 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Print copy is reduced
Go to the printer menu and check those settings. It is a configuration problem
Oct 12, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Imageclass MF6530
the imageclass MF6530 cannot print in color it can only print in black and white. the only thing that this machine can do with color is to scan color documents to your computer otherwise it is a black and white copier and printer with color scan.
Jan 02, 2008 | Printers & Copiers
Paper misfeed
hi im jules_09.have you check the inside of the copier?open the front door then see if there a paper in the transfer the transfer is in front of you if the door is open.the check the fusing unit many paper jams happen in the fusing unit.then at the paper tray if you cannot locate the paper jam inside the machine look at the paper tray from 1 to 3.then at the side most copier have opening at the side look for the door so you can see if theres any paper stock
Nov 22, 2007 | Toshiba 2060 Copier
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
103 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
