Our IAG Dishwasher Model:ARDIG0 is displaying two reverse L's on the indicator panel. This has happenened perviously but we got it up and running by pressing multiple buttons on the control panel randomly. But now its back, has anyone seen this before.
SOURCE: My dishwasher control panel does not light-up
This is a common problem. I am about to replace my second control panel in two years. First time was under warranty and I hope this time will also e under warranty.
SOURCE: I can't get my dishwasher to start
Part Number: 99002254 you may need this part depending on model no
SWTCH-DOOR
View Larger Image
SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
SOURCE: Kenmore Elite Dishwasher- The touchpad
I have a Kenmore Elite model 665.15962990. I have had it for 8 years.
A few days ago the touch panel seemed to go dead and so did the LED.
After pushing the buttons several times the motor kicked on, but the
washer behaved strangely. The LED displayed what looked like Klingon.
After looking through the Repair Parts Lists with its exploded view of
the washer components, I narrowed the problem down to either the power
module (part # 9744031), the console assembly which includes the button
touchpad (part # [white = 3384101], [bisque = 3384150], [black =
3384100]), or the dual light display a.k.a. LED (part # 3383825).
I took the washer apart because I was told I can't return the power
module and it costs roughly $150 at my local appliance repair shop. In
looking at everything, the power module is the most likely candidate.
The LED is a separate unit and is powered by the power module. The
buttons are the same way. Since both of those separate components are
behaving strangely, my best guess is the power module is not powering
either of them correctly.
Also I found this link: http://www.askmehelpdesk.com/appliances/kenmore-dishwasher-not-working-all-27100.html
I hope this helps someone.
SOURCE: control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
