Question about Nokia 3109 Cellular Phone
Doesn't power on
Might be the power button. Anybody an idea to open the cover, without smashing to the wall ;)
regards
Button integrated in cover was slightly bended, for that reason the outside button was not able to push the inside button.
I removed the cover by putting my nails in between the body and the front cover and pull.
Inside the phone I was able to push the very small black button with my nail.
Posted on Jun 04, 2009
I have a craftsman garage door opener and recently it has started to open on it's own but only opens half way and stops.This has happened a few times so I currently have it unpluged..any ideas
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Dec 09, 2010 | Craftsman 34 Hp Garage Door Opener Chain...
We have a new remote control for our Liftmaster garage door. However after closing the door on our way out, we return to find the door open. What could be wrong?
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Jun 24, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door open and closes by itself bighornenterprises@live.com
HOPE THIS HELPS
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens by itself at 3 pm everyday
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem.
HOPE THIS HELPS
Mar 13, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Communication to the opener fails. The little green light on the door opener goes out. It eventually returns and then the door will work again.
HOPE THIS HELPS
Aug 02, 2009 | Liftmaster, Chamberlain, Sears Door...
I need to change the code on a 03 opener, someone in the community keeps opening my garage door with theirs.
(THIS CAN BE HIDDEN IN THE WALL)
HOPE THIS HELPS
Apr 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener activates itself--don't know how to correct it.
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Apr 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening/closing problem
Could be a bad wall button or a smashed wire.
Anytime a door opens and/or closes by itself, or remotes work intermitantly I look for a smashed wire between the motor unit and the wall button or a bad wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote.
HOPE THIS HELPS
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman model 139.53754 garage door opener ramdomly opens on its own.
HOPE THIS HELPS
Nov 11, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Battery does not last
HOPE THIS HELPS
Aug 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Nokia 3109 Cellular Phone Logo
512 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
