Door handle fell off of oven
Rachel, every range oven door I've seen, that was built in the last 20 years comes off the range by opening it about 6 - 8 in. from the top of the door frame, taking a firm grip on both sides about 8 - 10 in. down, bend the knees slightly, get a good grip on the door and pull up sharply. The door should release from the spring hinge on each side. Once you have it out you can lay it flat on the kitchen table, (preferably on a towel or cloth of some sort), with the inside facing up. There should be several screws that hold the interior portion of the door to the outer portion. If you remove these screws you should be able to remove the inner portion of the door, by pulling straight up, easily, and put it on the floor or if there's room, on the counter or table. Now you should be able to locate the holes the screws go into, to hold the handle on the door. If they connect from the interior, you should have found them when the interior was off the first time. Take them and install the handle. If there are none, find some chatterproof washers and put one on the inner side of each screw to keep them from loosening again. Once you have the handle secured to the door you should be able to put it back together. After you have assembled the two halves of the oven door, make sure the two hinge assemblies are pulled away from the frame of the oven at approx. a 35 degree angle. This is necessary to have the proper clearance to allow the door to slide down onto the hinges and grab on inside. The door should slide right down over the two hinges and then you can close it up.
