Question about Intel D845GVSR Motherboard
Disply problem in my system no display but ram and processor and also power cable also fine and monitor also fine display is not coming?
  • 374 Answers
I guess your computer is not booting.
  • Fix and tighten your RAM into the slot properly also clean the dust on the RAM with a soft cloth if any
  • check the cables for the HardDisk and CD Drive,they should not be lose
  • Take out all the USB connection [Flash/Pen drive,mobile,printer etc.]Try n change the Keyboard and mouse also.
  • Your computer Should Boot now.
Posted on Jun 04, 2009
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
Tip
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
Thanks
on Dec 08, 2009 | Computers & Internet
GA-8SIMLH no disply
Check display power, monitor connector , if this doesn't help give us more information. How much RAM, what graphics card, Which Operating System? Is there a light on the monitor. Is the ram new?
Jan 23, 2012 | Gigabyte Computers & Internet
My monitor doesnt come on i have model x163 what driver do i need
You don't need a driver for a monitor. It displays the signal that the Video Card sends to it. Check the power cable and monitor video cable at the monitor and at the computer. Disconnect these cables and then reconnect them and tighten the thumbscrews to secure the connection. If you have an onboard video card, you may have a problem with your motherboard, RAM, Processor, Harddrive or Video Card that is preventing the computer from turning on. If you use a PCI, PCI-Express, AGP, etc. video card, check to make sure is it securely seated in it's slot. Also check the power cables going to the video card (if any) and the monitor cable connected to the video card. Else you may have a failed video card, or a problem with your motherboard, RAM, Processor, Harddrive or Video Card that is preventing the computer from turning on.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 11, 2011 | Acer X163WB Monitor
Sir procceser fix the board and . suddenly damage the the board and not come a disply which problem
If you have replaced the processor and have fix it then suddenly after a while the display in your monitor is gone, the video card in your motherboard could have come loose.
Detach this video card from the motherboard and reseated this properly.
Make sure also that the vga cable is fix properly on both the video card and the monitor.
Post back if you still have problems.
Feb 08, 2011 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
It doesn't send a signal to the monitor
Initially check the monitor whether it is working good you can check it by removing the monitor cable from the system when you remove cable you will able to see question mark in case of crt monitor this ensures your monitor is working good.
when you power the system whether processor works if the processor works means you can conclude that the problem is with the ram or the video parts of mother board.
Clear the dust in the ram slot and reinsert the ram
Then remove the cmos battery of the system and reset the bios settings.
Check whether the power cables are correct.
then power on the system if you receive display the problem is solved.
If the display does not appear check by replacing the new ram then giving motherboard to service centre
Mar 10, 2010 | Mercury P4VM800M7 Motherboard
My Samsung monitor 244T blinked several times and went black. A few days later I rebooted my computer and it blinked twice and went black. Now power light doesn't even go on. Help!
1).check your monitor cable and power cable.search google for how to check if you do not know...
2).change your RAM into another slot and check if u have 2 RAM interchange it and check..i prefer this must be the RAM problem..
normally when u insert any new RAM..sometimes it does not matches.. in this way the blinking can be happened...
3).disconnect all the cables of CD drive and DVD drive and any other except harddisk cables...and start the system with harddisk and without connecting the CD and DVD drive..
4).clean your processor cooling fan..search google for cleaning cooling fan..this makes the processor to reduce heat or apply cool paste to processor..
let me know that your computer monitor works fine with the above steps...."rate"
Feb 02, 2010 | Samsung SyncMaster 244T Monitor
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Monitor display problem..
Change yor keyboard. If any one key remains pressd or if any pin is bent then evrything seems to work but there is no Display and no beeps or error messages either!......i too suffered the same once................sodeep
Mar 18, 2009 | Computers & Internet
The power on my pc keeps recycling
remove all hardware except RAM n CPU and then try it if the system gives you a disply then add all hardware 1 by 1 and keep checkin this way you can find the problem with the harware compatibility if the system wont disply then check the mobo for RAMs and CPU respectively if the problem presists then you have the BAD BOARD.-
Jan 16, 2008 | Intel D845GLLY Motherboard
Intel D845GVSR Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
