Question about Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign local extension.
  • Panasonic Master
  • 2,460 Answers
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Carl
Posted on Jun 04, 2009
-Set up : PROGRAM -> one of the line button (on the right) -> 2 -> phone no. ->STORE
-Call: Pick up the phone -> press the line button
( phihong1)
Posted on Sep 28, 2012
How to delete message and reset phone..
Posted on Jun 05, 2009
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I have the message CO Not assigned ,How can assig CO? panasonic kx-t7730
    Press program button, select button you want to program, dial 0 then dial CO number as in 001 according to which CO line you wish to program. If you are not sure which CO line is missing, check the button programming by the same method. Press program button then any programmable button and it will be identified in the LCD screen. The CO lines may be 2 digit if you have an older system as in 01, 02, etc
    Jan 26, 2011 | Panasonic KX-T7730 Corded Phone
    I assigned a button for one-touch dialing on my KX-T7730, but I cannot cancel it. may you help me?
    You can assign something else over the top of it, or sometimes you can press the TRANSFER button and STORE to clear it.
    Carl
    Jun 21, 2010 | Panasonic KX-T7730 Corded Phone
    How to set speed dial on panasonic kx-t7730
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
    3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
    4. Press AUTO DIAL / STORE to save your setting.
    5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
    6. Press PROGRAM to exit program mode.
    7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
    Apr 12, 2010 | Panasonic KX-T7730 Corded Phone
    Panasonic kx-t7730
    Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
    PLEASE vote if this was helpful
    Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
    I need help setting speed dials on a Panasonic KX-T7730!!
    Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
    PLEASE rate this answer if it was helpful.
    Thank you.
    Sep 14, 2009 | Panasonic KX-T7730 Corded Phone
    How do I programme numbers into the KX-T7730
    hi kim
    if u mean how to store a phone number on a Flexible button, her is the way:
    1. Press Program button to be on Programming mode.
    2. Press the desired Flexible button you wish to assign as a One-Touch Dialing button.
    3. Dial 2.
    3. Enter the desired number (extension number, phone number, etc.).
    4. Press STORE.
    Ali
    Aug 25, 2009 | Panasonic KX-T7730 Corded Phone
    KX-T7731 messed up the co button
    Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
    Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
    Easy when you have the manual :-)
    Carl
    Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
    One touch dialling
    to return to it original settings, press prog button then press the button that you want to change, press 0 and enter its original button assignment
    Jun 28, 2008 | Panasonic KX-T7730 Corded Phone
    STORE NO FOR ONE TOUCH DIALLING
    press prog. button then press the one touch button, press 2 then 9 or 0 (depending in your line access no.) enter the contact no. then press store button.
    Jun 26, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    1,478 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
