Question about Refrigerators
Water is leaking from unit in the back of the refrigerator in which the icemaker/water line is inserted. Is this worth fixing? How much will this cost? Thanks.
  • 739 Answers
Is it fixable? yes, of course
if the fridge is still in good to great shape otherwise it's probably worth it to do so
How much it will cost is not easy to estimate, a simple cut and reattach, assuming you have enough water line for that, is just labor, hour, hour and a half...a splice a little more...a custom piece replacement requiring the removal of every component in the refrigerator? pricey..... a lot depends on the specific model, and the price of labor in your area
Posted on Jun 04, 2009
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
Hello! I have a Kenmore refrigerator model #10656576400. It stopped making ice for a while but then started up again. Now it is leaking water and filling up the tray underneath the ice cube mold. Is it...
The first thing to check would be the water fill valve located usually on the back outside of the unit where the water line comes in, these can start leaking water slowy into the icemaker. The icemaker itself tells the valve how long tostay opened, that can be adjusted by a tech or you may need to replace the icemaker
Jun 24, 2011 | Refrigerators
Icemaker not making ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag PSD2450GR fridge - water line for icemaker on back seems to be leaking can I replace or fix it some how?
yes first check to see your tubing size then go to home depot or lowes and pick up some quick connect and soe tubing the same size cut both ends of the tubing evenly insert a connector on each end and insert the tubing to each other end .Make sure you shut off the water before doing this
Apr 27, 2010 | Maytag PSD2450G Side by Side Refrigerator
My icemaker went on the blink, found water all over kitchen floor now it will not make ice but the freezer functions great. Model number ED2FHAXB04
Sometimes the water inlet are of an ice maker for no reason will freeze up preventing water from reaching the tray and making a mess. What will happen is the ice maker fill tube on the back of the cabinet also freezes up. As a result the icemaker tries to cycle pressure then builds up in the plastic feed line to the fill tube. This pressure build up in a very "low pressure" plastic line causes that plastic line to push itself out of the press to fit connections (fittings) at the back of the unit or under the unit. Hence the next cycle it just ports water to the now open line causing water to go to the floor instead of the icemaker.
You can locate the source of the leak by simply following the plastic fill tube and re-insert it into the fitting. You still need to find the ice build up that caused the initial leak and melt that ice buildup with a hair dryer or a fan until it is clear. Once you clear the ice blockage (near the rear of the icemaker) it should work normally again.
Feb 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker not getting water. I came home to find water all over the floor from my refrigerator. I turned the water supply off in back of the unit and a couple days later started investigating. Changed the...
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 18, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaker not working
Check the water inlet located at the back of the fridge.
Jan 06, 2009 | Whirlpool GS6NBEXR Side by Side...
My Ice maker stopped working (no water for ice) I replaced the water supply solenoid and plugged it back in. Ever thing worked fine except when the water valve cycled open. Water began leaking from the...
Yes, the short tube that goes from the back of the refrigerator to the icemaker can freeze up solid preventing any more water to pass thru. this is caused by a bad water valve that is slowly leaking water to the icemaker.
Jul 05, 2008 | Refrigerators
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
