Question about Acer Aspire 5735 Notebook
Monitor won't work and keyboard won't work
I think that my monitor and key board on my laptop think that they are hooked up to an external monitor and keyboard. I say this because when I boot my laptop and it goes into windows, I get no visual until I hook up an external monitor. Then I have to hookup up an external mouse in order to move the mouse around. Is there a hotkey I can press to fix my problem?
  • 298 Answers
Can you please share the Make and model of the Laptop?
Posted on Jun 04, 2009
My samsung n150 keyboard not working and my screen is broken what can i do to connect to external monitor
Dear Ronald
Pl. remove the key board connector from the main board and tape it.. Connect the external key board and monitor to its port.
That will work. It will better to disconnect the internal display connector.
Thanks.
Feb 22, 2015 | Samsung N150 Notebook
LAPTOP COMPAQ SCREEN WILL NOT LIGHT UP
on top row of keyboard try F-1 thru F-12 press the Fn Key (Bottom Left) and one of the F- keys at the same time there should be a picture of a monitor/screen on the correct F- key if that does not work hook up to external monitor to check the on board graphics chip
Dec 29, 2013 | Computers & Internet
How to use external monitor on a toshiba laptop with external monitor
It's probably best to buy a keyboard off auction sites or a new screen, the Function keys are not OS sensitive so a different keyboard will not work with them, they are device specific and require special drivers to operate.
Are keys broken or are they just missing? the membrane will still work to a firm press even if the key is missing.
keyboards can be found on auction sites
sorry I can't help more.
Apr 25, 2012 | Toshiba Computers & Internet
Blank black screen laptop on acer 5520-5012, Hook laptop up to external MONITOR works great. Did a command on keyboard..and both internal and external monitor works.
So connect your laptop to an external screen. Turn your laptop on. Press start key on your keyboard and then press "P" key on your keyboard. Remember you must press them simultaneously. A small window will popup. Choose Computer Only. Hope it helps I assumed that you are using windows 7 or vista Do not forget to rate your answer.
Oct 02, 2011 | Computers & Internet
Monitor is cracked. Have hooked up a Monitor still cannot get signal. I am guessing there are some buttons on the laptop keyboard that I need to press. Can you help please?
By default, the external monitor connector is turned off. Hold down the Fn key and press F4 to enable the external monitor. If you look closely at the F4 key you'll see it has a little picture of a monitor screen on it. Full information about the other keyboard functions is here at HP.
Dec 04, 2010 | HP Pavilion dv6000z Notebook
Acer 5515 on external monitor
Get an VGA cable and connect your external monitor to your laptop via a VGA port that is usually used for digital projectors. In this VGA port, you can initiate dual monitors.
Then look at your keyboard and look an icon in your function keys (F1 to F12) that looks like a pair of an LCD and a TV like this {LCD icon/ TV icon}. In most laptop keyboards, this is located in F4.
When found, and with the external monitor hooked to the laptop via VGA port using a VGA cable, press and hold down the FN key and press the function key where the icons described above is located. Example, FN + F4 to toggle a single and a dual monitor.
Give it a try.
Jun 26, 2010 | Computers & Internet
I am running Windows XP on my laptop. I plan to give a presentation using Powerpoint, and I'd like to plug a projector into the laptop. I cannot figure out how to play Powerpoint's presentation on the...
Couple ways. If you hook up the projector before turning on the laptop it should work. The preferred way, however, is to 'toggle' to the external moniter on your keyboard. Look for a icon on the Function keys (usually F4 or F5) on the top of your keyboard that looks like an external display. It may have a color, like green. It the lower left there maybe a key of the same color. You need to hold the lower left key while pressing the F key at the top. It will likely toggle between the external monitor only, both monitors, and internal only. Good luck.
Jan 07, 2010 | Computers & Internet
Can't get my laptop to display on a monitor.
Most laptops require you to press the Fn (Function) key and another key on the keyboard to activate the external video port, not too sure which button on your model it is, but it should look like a monitor.
Other than that it could be your board is fried. Which will need replacement/ repair.
Dec 10, 2008 | Toshiba Satellite A105 Notebook
Blank screen
I think your LCD is stuffed is it under warranty do you know BUT if the screen is cracked they wont replace it typical HP. To get your external monitor running hold down the function key and the blue monitor looking key similtaneously normally on compaq its the F4 key but look around your keyboard (looks like a monitor) and is blue letters.
Sep 18, 2007 | HP Compaq Presario V2000 Notebook
Installing an external monitor to a Toshiba A10 computer
press the FN and F4 keys similtaneously. That will switch the monitor from the LCD to the external monitor. But look on your keyboard it will indicate which buttons to do this for your model. The indication is hughlighted by the blue icons on the keyboard?
Sep 10, 2007 | Toshiba Satellite A10 Notebook
Acer Aspire 5735 Notebook Logo
195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
