Question about Tissot T33.1.588.51 T-Touch Dial
Tissot T-Touch I can't get the hands to synch with the digital and when in compass mode the hands point in the same direction and are neither in the correct direction.
  • Anonymous Jan 09, 2008
    cannot make the hands match the digital display
  • Anonymous Jan 11, 2008
    i have the same problem. did you ever figure out a way to fix it? also, when i touch the screen for anything else but the center, the hands are way off
Hello, if u read the user's manual, there is an option to resync the hands. Goto the units mode ( Press the middle button, and then twice in the center of the screen, so that the digital display shows either 24h Cm or 12h... u get it ) Once in that press and hold the middle button for 5 seconds, until the display shows SYNCHRO. Then use te top button to adjust the minute hand and te bottom button to adjust the hour hand, and bring them both, one on top of the other, over the 12 o'clock position. Once this is set, press the middle button again. This should to the trick.
Posted on Dec 12, 2008
Touch the t button once middle,
touch the middle units screen center of watch
push and hold t button for 5 secs, until the synch comes up
then + & - buttons until both hands are at 12 o'clock
than touch the t button to validate
Posted on Jul 16, 2009
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Jan 24, 2011 | Tissot T-Touch T33759851
Setting my Tissot touch Navigator 3000
Per the manual: http://support.tissot.ch/usersmanual/140-en.pdf
When your battery begins to die, the hands are no longer synced.
After replacing the battery, go into local time mode (pressing the center of the crystal) until "Set" appears. Press the crown. Scroll to "ECO BAT", press and hold the crown for 5 seconds until "SYNCHRO" appears. Use the "+" button to move the minute hand and the "-" to move the hour hand until they are in the upright or 12:00 position.
Either press the crown again or wait until the watch automatically leaves the Set mode. Your hands should now represent the local time.
Feb 08, 2010 | Tissot T Touch Navigator 3000 T96.1.478.32...
I adjusted the hands when on usin the compass function and when the hands reverted back to the time it was not correct even though the digital time reads just fine..How can I get the watch hands to mimic...
The manual will tell you how to do this. To obtain a copy type "support.tissot.ch/?mod_flashPDF/id_138" into your search engine and this should take you to the manual page for your watch.
Jan 22, 2010 | Tissot T-Touch T33159851 Wrist Watch
The digital and hands display different times on my Tissot Touch
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Dec 07, 2009 | Tissot T-Touch T33759851
Digital/analog times not same/# of batteries
You need to synchronize the watch. You can find directions to do that online, but you will likely have to do this several times a year. There are so many functions that you will occasionally need to go to synchro mode to synch everything up. It freaked me out the first time I saw this too. : )
Jun 27, 2008 | Tissot T-Touch T33759851
Tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
TIME IS NOT THE SAME AS THE DIGITAL TIME
  • Push the middle (T) button.
  • Touch the screen in the center selecting the units mode (24 C m).
  • Push the middle (T) button again for 5 seconds.
  • "SYNCHro" will appear on the display.
  • Use (+) button for min arm and (-) for hour arm.
  • Bring the two hands pre-cisely to 12 o'clock.
  • Press the middle (T) button to validate the setting.
Oct 10, 2007 | Tissot T33.1.588.71 Wrist Watch
Tissot issue
I have a similar problem which started this morning. My watch is almost 5 years old, and is on it's original battery. I suspect this is the first sign of the battery dying.
Jan 28, 2007 | Tissot T33.1.588.51 T-Touch Dial
Tissot T33.1.588.51 T-Touch Dial Logo
339 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
