Question about Panasonic KX-TG2303B/WH Digital Cordless Phone
Automated response request doesn't recognize numbers entered.
Is pulse or tone the correct setting to be able to respond to automated requests for entering numbers on my panasonic KX-T3968-B phone. Must enter every number on my phone several times before it is finally accepted.
  • 146 Answers
SOURCE: tone delay
Here is a link to the operating manual which may help :
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
You could try disconnecting the phone by unplugging it for abaout 10 seconds, then all phone settings would revert to manufacturers default settings.
Posted on Jan 21, 2008
  • 168 Answers
SOURCE: No tones, just a click when dialing
Try setting it on pulse, then hear it click when you push the number, if it works switch it back and try agian
Posted on Mar 05, 2009
SOURCE: change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Posted on Mar 23, 2009
  • 10 Answers
SOURCE: How to switch from pulse to tone at Panasonic
Is this a KX-TS 208? If so follow this link - http://service.us.panasonic.com/OPERMANPDF/KXTS208W.PDF and follow settings dialing mode instructions.
Posted on Oct 17, 2009
cnavarro
  • 2460 Answers
SOURCE: My KX-T7030 phone will not send a tone during a
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Posted on Dec 09, 2009
When I call a number and they want you to press certain number on your phone,well on my phone I can't press any number except to dial a number.
Check and see if your phone is set to tone or pulse? If it is on pulse you need to change it to tone. If it is on tone, check and see if you have a send button, you may have to press it after you press the number...
Jun 27, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
NET10 W408g does not allow using the Xlink gateway fully, especially sending DTMF codes to automated systems.
Jim
Been a long time since I have seen this phone but I seem to remember a setting like this. Some phones had a long and short setting too.
Mark
Motorola Support
Activate DTMF tones: Menu > Settings > Initial Setup > DTMF When you dial a number, your phone sends it to your network as Dual Tone Multi Frequency (DTMF) tones. To send DTMF tones during a call, just press number keys or scroll to a number in the phonebook or recent calls lists and press Options > Send Tones
Dec 17, 2012 | Motorola Mobility W408g - Silver net10...
How can i get my dial pad on my lg vu plus back on while on a call so when prompted to press a certain number by my credit card companies i can do so? as soon as i make a call the screen goes blank like in...
You need to go into your settings, sounds, key tones, and change from short tone to long tone. I've had this problem before with certain phones, but not all. this should let the automated service recognize the corresponding key you have entered.
Nov 13, 2010 | LG Cell Phones
I need to block a mobile number.
Wlcome to FixYa
Do Following:
  • Determine the number that you wish to block. If it's a harassing call, write down the number that appears on your caller ID. If the number is coming from an automated system, you may need to call the owner of the institution responsible for the calls, and have it corrected.
  • Call your cellular provider's Customer service department. This phone number can be found on the provider's website.
  • Avoid the automated system by continually pressing zero. With a representative on the phone, identify yourself, your account, your phone number and provide any password information if instructed. Explain your request to the representative, emphasizing the speed with which you need your request filled. Offer your phone number and the phone number you wish to block on your account. Obtain the representative's name, title and extension.
  • Contact your cellular provider's technical support department immediately after speaking with the customer service representative. This number can also be found on the provider's website. While a customer service representative may have already handled the problem, technical support can verify its completion. Provide the customer service representative's pertinent information to clarify and expedite the tech support's search. Ask if your request has been handled, technically-speaking. Obtain the tech support representative's name, title and extension.
  • Wait 24 to 48 hours. If the phone calls continue from the blocked number, contact customer service. Immediately ask to speak with a supervisor or manager. Explain to the superior your unresolved issue, provide the names and extensions of the previous representatives, and wait on the line until the number is successfully blocked. Again, ask to be transferred to technical support to verify the correction. If the problem continues, repeat until it is resolved.
So you need Assistance of Network Provider to Block...Hope you got an Idea...If this Helped you-Vote Me..Thanks for Contacting FixYa....
Jun 23, 2010 | HP iPAQ 510 Voice Messenger Smartphone
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
SPO MEDICAL PULSEOX 5000 - CHANGED BATTERY & ONLY READS 8'S
I sent a request to the company here is the response. Their website is www.spomedical.com.
Please contact our Customer Support facility at 1-800-548-6705; Mon-Fri; 6am-6pm PDT. They will be more than happy to assist with the issue at hand. We only request that you have your PulseOx 5500 serial # and date of purchase to verify warranty status.
Mar 20, 2009 | Exercise & Fitness
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Panasonic KX-TG2303B/WH Digital Cordless Phone Logo
42 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
