Question about Danby DCR34 Compact Refrigerator
Brand new danby dcr34bl refrigerator not working
Plugged it in and nothing is cold... why? I bought it online so it's much harder to return. Am I forgetting to make sure something is on? The thermostat is definitely on...
  • 739 Answers
Often times refrigerators need to sit for a day or so before being used, moving them scatters the refrigerant through the system making them useless.
It is also possible that durring shipping the system may have been compromised, allowing the refrigerant to escape. Have a technician check it out before you try to return it
Posted on Jun 04, 2009
It's a Danby and brand new i won it why and how do I fix problem of fridge not getting cold ?
dambys a usually very good
humm
not getting cold even when dialled to coolest
how long has the unit been on
can you hear the motor /compressor
kicking in and out or running at all
which model and size is this danby then
i can get a look at its user manual
http://kitchen.manualsonline.com/manuals/mfg/danby_products/danby_products_refrigerator_product_list.html
May 19, 2016 | Danby Refrigerators
My danby wine cooler does not get cold enough
Cool enough? You know most wine and beer only like it about 50 degrees and not any cooler. If it up at 55 and you have set it lower then the room is probably warmer then it can handle to cool them. I have some in the garage but in July and August the struggle to stay any cooler then 55 but then they are not expensive units either. Danby is cheap brand too. Nothing they make is that great.
Oct 07, 2014 | Danby Refrigerators
I HAVE REFRIGERATOR FEW WEEKS AGO MY REFRIGERATOR STOP WORKING WAT CAN I DO. IM NT SURE if I warranty on The serial number is 0109120102626 & model is dcr34bl
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Danby Refrigerators
My Danby refrigerator stopped working after the power went out over the weekend. I have adjusted the temp. dial but nothing appears to make a difference. Is there anything I can do to reset the fridge?
Try to unplug it again let it set 5 min and then plug it back in. If that doesn't do it you may have to replace the compressor relay where the wires hook to the compressor, thats a fairly easy fix on that unit.
May 17, 2011 | Danby DAR483 Compact Refrigerator
Danby DDR-7009-REE. This is my 2nd. The 1st unit did not remove any moisture. The new one removes some but nothing as expected. 1700 sq. ft. basement, air temp 62F, no walls-. Humidity is 50%+ and unit is...
It is not working well because of the 62 F temps... the cooler it is in the room the harder it is for the unit to work effectively...
heatman101
Apr 11, 2011 | Danby Dehumidifiers
2004 Hyundai Terracan, 2.5 turbo diesel, manual. Will not start cold. Once I get it started, it runs and starts perfectly, with some heat on the engine. Error Code P0110, I replaced the air intake...
right renew the glow plug timer/relay if you put a meter on the glow plugs when cold and turn ign on (with help) it should supply power for a about 20 secs ,time depends on outside air temperature ,if all else fails then do a colin --- use a push button switch,wired to a relay so glow plugs can be operated by pushing the switch which you will mount on the dash ,cant beat a manual overide system
Dec 14, 2009 | 2004 Hyundai XG350
Brand new wont get cold
I have a Danby Premiere Mini Fridge. It was sitting in the garage for a while.
I plugged it in and nothing, no sound .. no cooling.
The outlet is definately on. Do I have to push any buttons or reset something?
Thanks for your help.
Mario
Jul 06, 2009 | Danby (DAR604BLS) Refrigerator
New fridge not working
Try this:
Obviously, make sure the refrigerator is plugged in solidly and power is available.
Look inside the refrigerator and make sure the thermostat is set to about the middle of the range.
I believe this system may have a manual defrost button inside. If it does, see if it's stuck or if the unit is somehow stuck in defrost.
You mentioned it was new so barring these simple steps, take it back to the store
Mar 22, 2009 | Danby DCR34 Compact Refrigerator
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby DCR34 Compact Refrigerator Logo
367 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
