Question about Kenmore 22622 Top Load Washer
Water does not stop running when the washer is full.
The water in my washer kept running when it was already full. I did not wait to see how high it would fill once it got to the top of the drum. Thank goodness the spin cycle still works and I was able to get all that water out. Is there a gauge that is not working that would cause this? Would I be able to fix it by myself at home?
    Genius:
  • 1,122 Answers
Turn the water on for a minute,then turn it off,if it stops it's not the water valve,if it does not stop then it's the water level hose or switch that's bad-mike
Posted on Jun 04, 2009
My Samsung front loader is taking in water and flashing 0E. Can you help tell me what my problem is? Thanks
An OE code (not 0E) is an overflow error. Too much washing powder/liquid may have been added. Turn off power, wait 30 seconds and turn on power again. You should hear the drain pump operate to drain the machine.
Feb 22, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
My washer last nite kept filling up w water. & never would stop (until i stopped it myself)- its like the Sensot-or full indicatrer? stopped working- & needless to say it fllooded my laundry...
there is a water height sensor -- this sensor works via a small tube that is connected to the outside drum and runs down to the pressure sensor,, when water reaches a certain height the pressure sensor stops the fill cycle.
c...
Dec 31, 2010 | Maytag Washing Machines
Kenmore heavy duty 70 series washing machine, water won't stop
sounds like the washer water inlet valve is bad or the water pressure/level switch is bad or clogged or disconnected.  without knowing model hard to diagnose beyond this.
Jul 30, 2010 | Kenmore Washing Machines
Fills water & stop
I had the same situation but it is now fixed. Be sure your hot and cold water are both turned on, even if you use the COLD / COLD . My washer kept stopping in mid stream.Haven't had a problem in a month
Jan 29, 2009 | Frigidaire FTF530FS Front Load Washer
Washing machine
it needs a new water valve
Nov 16, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22622 Top Load Washer Logo
98 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
