Question about Husqvarna Husky 165
Piston ring the compression has gone on my husqvarna 346xp,so i asumed it would be the piston or the piston ring,however the piston looks fine but the ring is quite loose and im not sure how loose or tight it should be round the piston, please help, thanks
    Problem Solver:
  • 11 Answers
The piston ring whilst the piston is still in the pot should be relitivly tight. This is because it creates the seal to maintain compression. When the ring is taken off the piston it only has about 4mm gap between the two ends, any more than this it's probaby knackered. worth checking pot and piston for scoring around the exhaust outlet as if it's going to loose compression it will be at this point. If all these are fine check the decompression valve (if you model has one) if this is broken your compression will be ruined.
Posted on Sep 21, 2009
Stitch length stuck husqvarna
Remove the needle plate and make sure there is no lint obstructing the feed dogs. If they are clear, it is usually the feed dog step motor gone bad. You should have your machine serviced by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the Husqvarna Viking website -
Sep 26, 2014 | Husqvarna Sewing Machines
Husqvarna model 183 foot control no power
anytime the machine does not respond like it's suppose to then it needs to be checked, the foot pedal could have gone bad, or the the sewing machine plug where the foot pedal goes may have gone out
Mar 27, 2012 | Husqvarna Viking 1
Husqvarna mega quilter is bunching bobbin thread when quilting. Top thread looks fine. I have tried adjusting tension. what should I look for?
try a new needle
clean these areas,,under needle plate,,,bobbin area
check to make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted correctly
Aug 02, 2011 | Husqvarna Sewing Machines
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Mar 23, 2009 | Husqvarna Viking 1
Chainsaw (Husqvarna 345e) will not start due to start attempt without adding oil to fuel.
If this was started without oil in fuel, then the piston is likely scored, and the compression rings stuck in a smeared aluminum mess. You can remove the muffler and probably see the damage to the piston. It can probably be repaired though. Take it to a reputible shop, then read the owners manual and get some help to learn how to safely use and maintain your investment that you have in this saw.
Jul 04, 2008 | Husqvarna Husky 165
Selections on display not communicating to machine
Sounds like the circuit board has gone bad. Suggest taking machine to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page -
Good luck.
May 11, 2008 | Husqvarna Freesia 415
Sewing Machines Logo
153 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
