Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
AFTER I GET TRIMMER STARTED...
ONCE STARTED, WHEN I GIVE IT GAS IT DIES OUT
  • 1,040 Answers
You need to clean the carburetor. Or you need a new carb.kit. If you need tips on how to best do this, just let me know.
Jim
Posted on Jun 04, 2009
  • Jim Parker
    Jim Parker Jun 09, 2009
    Did this solve the problem? You may also want to check the fuel lines for breaks if it is an older trimmer.
    Jim
Why wont my trimmer take gas after it starts ?
Open, turn ccw, the high 'H' speed jet screw about .3 of a turn while holding the throttle wide open at the trigger. Engine should increase spread andyou may have to adjust. Failing that and assuming correct oil/gas mix it will likely be carburetion, clogged fuel filter or bad fuel line.
May 02, 2014 | Husqvarna 128LD 17" Gas Trimmer
TB425CS
can u explain little bit clearly?
Sep 28, 2008 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Machine will start but won't stay running. give some gas and it runs for a couple of seconds and then dies. i did replace the spark plug but it is doing the same thing. it is a 25cc craftsman weedwacker...
I had a similar problem and it was simple to fix. I hope yours is the same. The line going into the gas tank is not far enough down in the tank.Once you prime it with the primer bulb , it will run till that gas is gone. No fuel from the tank is getting to the carburetor. If you've replaced the fuel lines recently, this may be your problem. If not, try cleaning the fuel tank and the carburetor. Hope this helps.
Sep 08, 2010 | Craftsman 25cc Gas Line Trimmer
Husqvarna SRM 225 It starts fine but dies once you give it gas.
I was having the same issue with my 128LD string trimmer. I called a local Husqvarna service dealer and they told me the issue was a result of the ethanol in the gas. They suggested I find ethanol-free gas (aka 'Pure Gas') and try it. [http://www.pure-gas.org/ was the best resource I could find for this]
After disposing of my old gas and filling the trimmer with premium grade, ethanol-free gas (with Husqvarna brand oil mix) and applying 3 squirts of carburetor cleaner to the carb, it runs radically better.
I hope that helps you too. I know how frustrating that can be.
Jul 21, 2010 | Husqvarna 225cc Hedge Trimmer 22" Cut HVH...
Troy Bilt string trimmer starts but dies when I try to give it gas to trim.
Try mixing up some fresh gas mixture if it is over 30 days old it is considered bad gas. Or the carburetor may need to be rebuilt.
Sep 30, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas won't pump through the hedge trimmer
carb may need to be rebult. sounds like a bad diafram hope this helps
Jul 11, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Troy bilt 4 cycle string trimmer wont stay running when given gas it starts fine but once you try to give it gas it dies
If this is an old unit, then the diaphragm is probably hardened.
Tests before hand would be:
1. Is the gas fresh and water free?
2. Is the spark-plug clean and snugly fastened?
3. Are you using the correct gas to oil mix ratio in your fuel?
4. yes...yes...yes...= bad diaphragm. Probably less than $5 for the part and a 1/2 hour to replace the part.
Jul 07, 2009 | Troy Garden
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Husqvarna Forest & Garden 125c 17" Curvgastrimmer Logo
243 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
