Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
HOOVER F5906-900 I am having trouble figuring out where the inner hoses go, A friend barroed it and took them off to clean them and did not put them back properly. Would you please send me Scamatics to see where exactly these go so I can shampoo my carpets before I go crazy. Thank You Misty Winslow StMisty@netscape.com
  • Anonymous Oct 10, 2008
    Can someone send that screenshot of the schematic to me (the one on the site is too low res) My E-mail is Lewisjetpilot@yahoo.com Thanks
    President:
  • 1,673 Answers
Here is a break down, you may be to trace the lines:
Posted on Feb 14, 2008
The suction stopped working after emptying dirty water and filling up with new water and cleaner
I have an older Hoover SteamVac Supreme #F5815 and I'm having trouble figuring out how to clean the part in the front that the dirty water goes thru before it gets to the tank. How do I clean it?
Mar 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Can't switch cleaning mode from tool to floor
there's a mechanism inside the steamvac that should switch the mode automatically when you press the handle release and pull the handle down for the vacuum mode... it's automatic! it took so long to figure out because I kept looking for the switch when it was upright and didn't look as I was using it.
Aug 25, 2009 | Vacuums
No suction for upholstery hose
http://www.hoover.com/pdfs/manuals/F5914900.pdf try priming your hose
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
Follow the instructions on pages 14 and
15 for the appropriate cleaning task.
Godbless
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do I attach the stair cleaner attachment
  1. remove recovery tank lid
  2. remove tank duct from front of tank
  3. slide flat end of hose into slot where tank duct was<open side up>
  4. place tank lid back on
  5. open water hose door on hood
  6. push waterline onto spickett
  7. clean your stairs.
best of luck
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction on my vacuum. Hoover Tempo
try to clean between the roller and the tube to the hose
May 05, 2009 | Vacuums
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=428640
Cleaning hose
Posted by NNate on Mar 06, 2008
I can't get solution to come through my hose attachement to clean furniture
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sound to me that you may have a defective pump or switch, the sprayer or solution should not spray out unless you use the trigger. Question? How old is the machine – if it is less than one year this would be covered under the Hoover factory warranty and if it is more than one year than you may want to check the trouble shooting part of the owner’s manual or to call the Hoover tech support line @ the factory. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Mar 06, 2008 | Hoover F5881-900 Vacuum
Hoover steamvac clean surge turbo power 5200 attachment problems
That part to install in tank, is at the end of your hose. Take the lide off of the dirty water tank, on the front of the tank, there is a block that will slide out, then you can insert that part in its place. You have to have suction to make the brushes spin, so you just need to put the block on the end of the hose in the slot on the front of the tank. When down however, put that block you took out back, or your cleaner won't work right.
Jan 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Converting the machine to use the uphostery brush
Remove the duct (#3)in front of the water tank. Your hose on one end will have a duct on it, insert it in the place of the duct that you took out. Don't forget to put that duct in when you are done with the hose.
Sep 29, 2007 | Hoover F5807 SteamVac Wet/Dry Vacuum
Hose breakage
The same thing happened to me last week. The inner hose does not have enough "extra" play so if you bend the handle down too low to reach under a dresser or bed the lower inner plastic hose snaps. I brought mine in to be repaired since it's under warranty. I did a long exhaustive search and came across this website1.gif https://www.mdappliance.com that has Hoover Agility replacement hoses and their prices are the best I have found so far. The smaller inner hose (part number 90001080) is only $9.99 (compared to $13.99 & $19.99) and the external hose attachment (part number 91001004) is only $25.99 (compared to $39.95). I specifically asked and the parts are brand new... not refurbished or used. Their phone1.gif number is 866-914-1252. Just in case you're wondering, I'm not a rep for the company nor do I have any affiliation with them. I just placed an order for the hose attacment and came across this webpage1.gif and figured I'd add my 2 cents. Hope this info is helpful. I tried to make it as complete as possible.
Goiod luck.
PS: They also offer a flat rate shipping fee of $7.95 regardless of what you order. No sales tax unles you're in Ohio. :)
Sep 21, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
157 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
