Question about Car Audio & Video
Cd stuck wont open - Car Audio & Video
    President:
  • 1,734 Answers
These tricks are focused mainly on single disc CD players but they may work on your multi-disk changer. Usual disclaimers - attempting repairs can ruin your player. If your car is under warranty, take it to the dealer. If you have any qualms about trying any of these techniques, let a dealer or audio shop tackle the project instead.
Tips and Tricks:
Figure out what fuse controls the CD player and, with no key in the ignition, pull the fuse out for a minute (or more - I've seen TSBs that say leave the fuse out for 10 minutes), then replace it (theory being that the fuse acts as a reset button). If you cannot find the fuse, you can disconnect the negative battery cable, but you'll lose your radio presets and other settings. Make sure you have any codes for your radio that may be required since disconnecting the battery cables can cause the radio to quit working too. This fuse trick seems to have the greatest chance of success overall. Check your owner's manual - you may have more than one fuse that controls the CD and/or the radio and you may need to remove all the related fuses. (There's a "risky" variation of this tip described in the Multiple (6-disk, etc.) Systems section of the guide for attempting to fix a CD changer)
Turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again).
Try using some tweezers, needle nose pliers or hemostats (every tool kit needs a hemostat or two!) to pull the CD out while pressing the eject button with power going to the player (theory being that the disc is so slick the player can't eject it without help). Some people report success just by pulling the disc out with the tweezers without power to the player and without pressing the eject button.
If your player has a small hole in the front of it, like most personal computer CD players do, straighten a paperclip and push the clip straight into the hole to manually release the catch. Some players have a groove under the CD door instead of a hole. Look for a hole about the size of the paperclip and don't mistake an emergency release hole for an earphone jack.
Some players, especially aftermarket ones, use a CD cartridge or magazine. Tapping on the cartridge while pressing the eject button sometimes ejects stuck discs. CarSpace member Alwaysfords2 has been able to remove stuck CD magazines by using a piece of shim stock or a hack saw blade and going alongside one of the long sides of the magazine to hit the release. You can rock the magazine a little bit in the slot to see the mechanism and it should be easy to release - sort of like using the little pin hole on a CD drive, the magazine pops up as soon as it is freed.
Remove the faceplace from your player (be gentle; something like a butter knife often works without damaging the bezel or breaking tabs). Then look for a tiny, usually recessed little button that you can press. You may need that unbent paperclip to reach the button.
Find a coaster in your junk drawer - by coaster, I mean an old CD that doesn't work. Or use a blank one if that's all you have. Insert the coaster about an inch into the slot (yes, on top of the stuck CD). Then turn the ignition on and hold the eject button and wiggle the CD around. Don't be hamfisted - you're just trying to give the player some traction to help it eject the stuck one. If this fails, then try slipping the edge of the coaster (or something even thinner) under the stuck CD and pry it up while pressing the eject button. Again, be gentle - you don't want to ruin the player when a pro may be able to remove the unit and free the disc for $20 or so.
Find a Popsicle stick or something thin but rigid and tear off a few inches of Scotch Tape from that roll you keep in your junk drawer (next to all those ruined CDs you intend to make Christmas ornaments out of some day). Put the tape on the top of the stuck CD using the thin stick to help attach the tape firmly to the disk. Like the hint above, the idea is to lift the CD enough to enable the player to eject it.
At least one CarSpace member had success releasing a stuck CD by, ahem, banging on top of the dashboard!
Foreign objects stuck into the player, or CDs that miss the slot entirely yet wind up inside the unit usually require pulling the CD player to remove the disc.
If all else fails and the repair is expensive, you may want to upgrade to an aftermarket unit.
Multiple (6-disk, etc.) Systems:
On some brands, pressing the load and eject button at the same time will cycle the changer and eject a stuck disk. If your changer uses magazines to hold the CDs, be sure to try the shim trick above.
Risky variation of the fuse tip that fixed a CD changer. Rbronosky in the Axiom 6-CD Changer discussion on CarSpace figured out which fuse controlled the CD changer. When pulling the fuse didn't reset the changer, he turned the ignition on just enough to run the radio. While the radio was on (and against his better judgment), he pulled the fuse and then replaced it. This operation caused a huge blue spark! But his changer immediately started shuffling, the eject button released the stuck CDs and the CD player worked like new. Because of the risk of fire and damage to other electrical components, this tip cannot be recommended. But if you like living dangerously....
Prevention:
A CD cleaning kit may be helpful in cleaning the CD laser lens and the demagnetizing the CD head.Tony78 reports that this can fix CD players or changers that are showing an ERROR or similar message.
Don't use homemade labels on any disks, home burnt or otherwise. They may be too thick for your player or the label may peel off inside the player, especially when the player or car interior gets hot and softens the adhesive. Use a pen made for marking on CDs instead.
Be careful with any CDs borrowed from your library too - they may have a bar code taped to the surface and be too thick for your player.
Don't use "scratch protectors" on your CDs.
Try to teach your kids not to cram nickels in the CD slot. :-)
Attempting to use an an unformatted-unfinalized and/or uncompatible cd disk in a CD changer can cause errors on the changer display and cause the changer to refuse to eject disks.
If this was helpful please leava a FIXYA! rating
Posted on Jun 04, 2009
Cd tray wont shut
all trays have a little switch inside it mybe stuck on open.
you might have to take it out,,open it up and see if its stuck.
or even a bit of dirt could stop it as well.or somthing stuck in there.
Mar 19, 2014 | Acer Aspire Computers & Internet
Insignia computer cd stuck in driver
Look for a little pinhole on the face of the CD Drive. Use a paper clip or a thin needle to in the pinhole to push open the CD Tray and retrieve the stuck CD.
Mar 09, 2014 | Insignia D400a PC Desktop
Caldine cd player wont tilt
The eject mechanism needs work and probably lubrication or a new belt.
Dec 25, 2012 | Audio Players & Recorders
Cd wont open
On the front of your CD player you will see a very small hole, insert the end of a paperclip and push gently, this will open your cd drawer, it is possible that it was just stuck or you have lost power to it (check your connections) if there is no visible problems with any connections and it doesnt work after you have opened it with the manual release, then all I can suggest is that you purchase a new one, they are quite cheap and easy to fit.
Jun 03, 2012 | Computers & Internet
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
My CD drive is stuck wont open up im using acer aspire4745
Hello
OK, you will need to force eject the cd/dvd stuck. You can read step by step instructions on how to force eject the stuck disc at the link below.
Click HERE to navigate.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 23, 2010 | Acer Computers & Internet
My cd/dvd drawer open or close. was stuck open. now has closed an
You may force eject the CD tray by inserting a paper clip inside the small slot or you may force restart your computer by pressing the power button for 5 seconds.
Jun 10, 2009 | Microsoft Windows Vista Ultimate Edition
Broken stuck CD drive
Make sure it's not being held by screws on both sides.
May 11, 2009 | Computers & Internet
The cd is stuck
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Sep 30, 2005 | Pioneer AVXP7000CD Car Video Player
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
