Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
It start my pc but it stop including cpu fan - Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
  • 298 Answers
Order a newone from places like newegg.com
Posted on Jun 04, 2009
Medion MED MT503 won't start or go through p.o.s.t.
When you say "fan" do you mean case fan or CPU fan? Almost sounds like the CPU fan is inoperative and the system is shutting down on CPU overtemp, then trying to restart.
Aug 01, 2014 | Medion Computers & Internet
Alert! heatsink not connected and system halted
well YEAH! the cpu has overheated because the heatsink and/or fan over the cpu has to keep it cool. if it overheats(easily done), your system will stop and it won;t start if the fan does not spin. fix the fan/heatsink. it possilby could have killed the cpu too? not sure.
Nov 18, 2013 | Dell OptiPlex GX620 PC Desktop
Fan speed zx6800
It depends on which fan you are talking about (CPU or Case) It would also depend on the heatsink you have fitted and the CPU that is fitted. The speed is about right for a CPU fan though. If your computer stops on it's own after a short while you may have an overheating problem. To check the CPU temp is in the correct range try CPU world website for the spec for your particular model.
Jan 12, 2013 | Gateway ZX6800-01 (PW.G8802.004) 23 in. PC...
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
I have a HP M1270N Media Center PC. The CPU Fan
The CPU fan is designed to run constantly to prevent the CPU from overheating. The speed depends on temperature condition of the room; slow in cold and fast in a hot room. However if you suspect that it runs too fast them try re-seating the CPU. WARNING: Re-seating should only be done if you are know how to do; don't experiment.
If it is running noisy, you can apply one or two drops of machine oil to the fan's spindle.
Other reasons include deposits of dust; use a blower to remove dust from the heat-sink.
To make sure you CPU is not in a critical state, log in the BIOS and in the hardware monitoring tab check the CPU temperature. It should be near 60 deg Celsius or 140 Fahrenheit.
One thing more, do not apply thermal grease in excess; its a conductive compound and can short the motherboard if it melts and deposits on the motherboard due to high CPU temperature.
May 25, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
CPU fan not detected
replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
Jun 29, 2009 | Computers & Internet
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Cpu Fan error
cpu fan might gone out of order, open your cpu cover, observe the condition of cpu fan, if it is idle, replacment is the best solution.
Jan 20, 2009 | HP (D9820-60007) Motherboard
Cpu fan starts then stops
Replace it and let us know if it still happens with the new one.It shut down because of overheating, I hope it didnt mess up your CPU.
Jan 06, 2008 | Biostar GEFORCE 6100-M9 Motherboard
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
