Question about HP PSC 1410v Printer
Installing HP 1410 All In ONe Printer
Uninstalled printer due to failure of print command . Trying to reinstall printer , after sometime error message " issue stopping installation : PRINT SPOOLER .
Clicking option FIX does not have any effect
  • 1,006 Answers
Change the directory off istalation and it will work
Posted on Oct 24, 2007
SOURCE:
I cannot print
Sometimes it can be due to failure of the printer head, failure of ink catridges. In some cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 17, 2011 | HP PSC 2210 All-In-One InkJet Printer
I have a problem with my HP PSC 1410 printer. When I want to print a file, the printer just does not respond. The file to be printed appears in the printer queue list without giving any message and the...
Right hand click on the printer driver and check if the printer has not been paused.
try using another usb cable, the usb cable could be faulty
Also set the printer so that it is the default printer.
Uninstall the printer driver and reinstall the driver
Feb 14, 2011 | HP PSC 1410 All-In-One InkJet Printer
HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
This eror usually mean that the printer cartridge has not been installed correctly. Try re-installing the cartridge. This error can also be generated by a logic fault within the printer.. if this is the case, replace the printer.. trying another new cartridge can be expensive so try and get a second hand cartridge, maybe from a friend and try that one.. Otherwise, replace the printer..
Oct 27, 2009 | HP PSC 1410 All-In-One InkJet Printer
Printer will print test page but nothing else
there is a communication failure between the printer and the computer. uninstall and reinstall the printer driver. your problem will be resolved.
Aug 04, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Jun 03, 2009 | HP PSC 1410 All-In-One InkJet Printer
Problem installing after resintalling windows xp
I would try uninstalling the HP printer software then reboot and reinstall the software.
May 17, 2009 | HP PSC 1410 All-In-One InkJet Printer
Printer begins to print fine and then all of the sudden it begins to print red lines across the picture.
Try re-installing the drivers from page below.
Also try a replacement usb cable , if the cable is losing connection during printing you may get same problem.
If that does not fix the problem, then the printer has a defective logic board.
Here is the support page. Try downloading and installing the drivers again , and replacing the USB cable.
If this does not fix the problem, then the printer is defective.
HP PSC 1410 All-in-One Printer
Feb 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1410 printer error message
I fixed the problem I was having by re-installing the program, which then told me exactly what the problem was. It was the color cartridge.
I then put a new cartridge in and it worked!
Jan 29, 2009 | HP PSC 1410 All-In-One InkJet Printer
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
My hp psc 1410 allin one
I would try uninstalling and reinstalling the printer. If you are using any version of windows you can uninstall it by going into add/remove programs (or programs and features under Windows Vista) and then reinstall it by downloading the updated drivers at http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441115&lc=en&cc=us&dlc=en&lang=en&cc=us
Also if the printer is giving an error message that would help if you would post it.
May 09, 2008 | HP PSC 1410v All-in-One Printer
Open Questions:
HP PSC 1410v Printer Logo
52 people viewed this question
Clive
Clive
Thomas F. Schneider
