Question about Mitsubishi WS-65611 65" Rear Projection Television
My tv turns on the shuts off on its own
Everytime I turn my tv on it shuts itself right back off. Could it be the bulb? Where can I find a replacement its a Mitsubishi WS-65611
  • 2 more comments
  • emilyeyork Jun 05, 2009
    Actually no lights blink at all when the tv goes on the green power light goes on but then immediately shuts off I tried to reset based on the manuals troubleshooting, but got no luck
  • techguy7 May 11, 2010
    Hi
    When it switches itself off the LEDs in the front (the lights)blink or they should do,how many times between each pause do they blink or is it just a continuos blink,or no blink at all just red LED?
  • Martin Forsythe May 11, 2010
    Your set does not have a bulb. It is a CRT rear projection set.
  • Larry King
    Larry King Jan 20, 2014
    when it shuts off, the green light stays on. It doesn't blink.
  • 126 Answers
This unit will not indicate any problem without you doing something to initiate the LED diagnostic feature. Go to the front of the set and hit the power button, when that doesn't work hold the MENU and INPUT buttons on the set at the same time for 10 seconds. The power LED should start blinking a two sequence code that will repeat six times. The number of blinks will tell the general area of the problem. As an example a 2 - 2 sequence is a convergence output problem over 95% of the time.
Posted on Jun 04, 2009
    Problem Solver:
  • 8 Answers
Look on ebay for that type of model and tv. for the bulb your looking it will probably be cheap and then search for replacement methods on ebay, so u can put it in if its possible self replacement
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
Hello, I have Sony KF50WE610. I have already
Blinks 4 times means a temperature error. Check the fans and if ok replace H3 board part# A-1405-433-A a small board located in the left side(when you are in the back of the TV).
Jan 03, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Panasonic pt 50dl45 shuts off buy itself
You probably have a lot of dust inside.
Open the back panel and vacuum.
Also use compressed air to blow into the components. Do not blow into the fan on the right as it will get the dust inside the lamp housing.
Oct 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Sony LCD Projection TV turning OFF!!!
I also have a Sony KDF-42WE655 42" Lcd television. We just changed the lamp (bulb) several weeks ago and has noticed that everytime we turn on the television it stays on about 30-40 seconds then cuts off. After about 15-20 seconds it cuts itself back on. Weird!! It must have something to do with changing the bulb!?!?
Apr 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Mitsubishi WS-65611 65" Rear Projection Television Logo
726 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
