Question about HP ProLiant ML150 G3 Server
When i repair my windows at my server (HP ML150 )
When i repair my windows at my server.error message "setup did not find any hard disk drives installed in yout computer".
  • 739 Answers
Reboot, and check to see if BIOS 'sees' the hard drive...if bios lists the drive, right click on 'My Computer' and select manage drives. the interface there is pretty straight forward... if bios does NOT see your drive, check your pin settings, be sure your connections are tight ...and check the BIOS settings match your drive
Posted on Jun 04, 2009
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
Hard disk not found message coming while installing windows server 2003 on Hp Proliant ML150 G5
You need to press F6 and load special drivers for your disk driver card
See which disk adapter your server has and get the drivers on a floppy disk
Put the disk into your computer before seutp, then click F6 when prompted
it will search your floppy drive for them
Feb 15, 2011 | HP ProLiant ML150 G5 Server
When trying to install window server 2003, i get the following error message. Setup did not find any hard disk drives installed in your computer Make sure any hard disk drives are powered on and...
The setup program does not recognise your storage controller.
HP and Dell usually supply a startup CD, that will help you configure RAID levels and partitions and start the Windows installation. If you have the supplied CD boot from it and it should work OK, if not you can download it here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=316541&prodNameId=327476&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-d7672226b6284520b9e292b9bd
Please let me know if it works, any issues send a reply :)
Dec 22, 2010 | HP ProLiant ML370 G4 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Dell RAID controller in HP server? Hi i have dell (Adaptec) CERC SATA1.5/6ch RAID card, now i want to use this card in HP proliant ml150 g3 server, after fixing this card server did not recognize it keeps...
This particular device will require drivers for the Operating System to use. Also the hard disk drives will have to be installed an initialized outside the Operating System first before use. This is usually during startup after the system BIOS.
The exact steps can be found on the RAID card manufacturer's web site.
Feb 18, 2010 | HP ProLiant ML150 G3 Server
How to install Win2003 on HP ML150 G2?
u need to have Win2003 install disk...
insert the disk in the CDROM drive
let it boot and load all system files and then it will ask u to format the disk
let it format the disk
and it will auto install the win2003 os
before u do this take a backup of ur data...
Dec 25, 2009 | HP ProLiant ML150 G5 Server
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Mar 02, 2009 | HP ProLiant ML150 G3 Server
Instalation of windows server edition
You have to make a floppy disk with the raid drivers on it. Start the Setup process and just as it's beginning it will ask you to hit F6 to install raid drivers. Hit F6, insert the floppy, install the drivers.
Feb 18, 2009 | HP ProLiant ML150 G3 Server
STORAGE
Hi, I found this thread interesting. Will try it out today.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?prodSeriesId=3799613&prodTypeId=18964&threadId=1285096&admit=109447626+1237817674797+28353475
It says that the right driver is not in the support CD!! As per the link, the problem was solved for him once he used a USB Floppy drive (Windows compatible).
Sep 08, 2008 | HP ProLiant ML150 G5 Server
HP ProLiant ML150 G3 Server Logo
308 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
